[Fwd: Re: WFS gurus . . . .]
Bob Basques
bob.basques at CI.STPAUL.MN.US
Mon Jun 5 11:12:02 EDT 2006
Kralidis,Tom [Burlington] wrote:
> Good question.
> What's your actual projection definition?
I believe this works (been a while though since I've tested it):
PROJECTION
"proj=lcc"
"lat_1=44.88333333333333"
"lat_2=45.13333333333333"
"lat_0=44.79111111111111"
"lon_0=-93.38333333333334"
"x_0=152400.3048"
"y_0=30480.06096"
"a=6378418.941"
"b=6357033.31"
"to_meter=0.3048006096012192"
"no_defs"
END
I have a list from someone in one of the State of Mn Dept's. that show
some codes for other Counties, but I think that's someone elses version
of an arbitrary list as well. I believe the TO_METER value above is
supposed to convert to Feet as well.
bobb
> CubeWerx (http://www.cubewerx.com/) holds the 42xxx projection
> definitions. We've worked with them to establish codes which are not
> natively in EPSG. I've cc'd Craig here for info.
> ..Tom
>> -----Original Message-----
>> From: UMN MapServer Users List=20
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Bob Basques
>> Sent: Monday, June 05, 2006 10:38 AM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: [UMN_MAPSERVER-USERS] [Fwd: Re: WFS gurus . . . .]
>> =20
>> =20
>> Ok, we'll try that.
>> =20
>> Any rule-of-thumb for assigning an arbitrary code?
>> =20
>> bobb
>> =20
>> =20
>> -------- Original Message --------
>> Subject: Re: WFS gurus . . . .
>> Date: Mon, 5 Jun 2006 10:32:23 -0400
>> From: Kralidis,Tom [Burlington] <Tom.Kralidis at EC.GC.CA>
>> Reply-To: Kralidis,Tom [Burlington] <Tom.Kralidis at EC.GC.CA>
>> =20
>> =20
>> =20
>>> =3D20
>>> I'm trying to get a WFS output in a local coordinate system. =3D20 =20
>>> Everything=3D20 works just fine with a EPSG code, but our coordinate =
>>> system is not in=3D20 the list. Do we need to add it in in more =
> than=20
>>> one location? We're=3D20 using a few extensions that all=20
>> seem to have=20
>>> their own=3D20 version of a EPSG=3D20
>>> code list, different formats and everything.
>> =20
>> What's your projection parameters? If it's indeed not an=20
>> EPSG code, you'll need to add this to your proj install's=20
>> epsg file, then cite that EPSG code in your WFS request. =3D20
>>> All I need is to be able to get the WFS output with a same=20
>>> coordinate=3D20 system BBOX. Can I get around the EPSG=20
>> requirement with=20
>>> some form of=3D20 fakery? Can the GML be output with a=20
>> MODE=3D3D option=20
>>> perhaps, in it's=3D20 native coordinate system?
>> =20
