GDAL, Mapserver and PostGIS
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Jun 7 01:26:22 EDT 2006
the preferred way to access PostGIS is through Mapserver. So you don't need
to compile PostGIS support into OGR (the vector part of GDAL).
You need the PostgreSQL client libraries in order to compile, aka libpq.
Runtime you also need the libpq .dll or .so depending on your platform.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Angus Dickey
Verzonden: dinsdag 6 juni 2006 20:10
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] GDAL, Mapserver and PostGIS
Hello all,
I notice both GDAL and Mapserver have options to be compiled with support
for PostGIS. Is it necessary to compile PostGIS support into GDAL as well as
the Mapserver executable? Also do Postgresql/PostGIS have to be installed on
the machine compiling (then running) Mapserver? Or are there just certain
PostGIS libraries that can be applied?
Thanks for any help,
~Angus
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060607/3ed06c6b/attachment.html
