problem with ogr oracle spatial layer
Howard Butler
hobu at IASTATE.EDU
Wed Jun 7 10:48:15 EDT 2006
Mark,
IIRC, the ogr_OCI.dll was linked against Oracle 10g. Is it possible
you have a 9i oci.dll somewhere in your path that it is picking up
when attempting to initialize?
Howard
At 09:18 AM 6/7/2006, Frank Warmerdam wrote:
>Mark Adams wrote:
> > Yikes. Can you give any pointers as to what I should be looking at? In
> > terms of setting up the environment, all I've done is install the Oracle
> > 9i client on the web server, and mapserver/mapscript with a version of
> > gdal compiled with the ogr_oci dll as a plugin. To have the plugin
> > recognized I set the GDAL_DRIVER_PATH variable (until then ogrinfo
> > didn't recognize OCI as a supported format) to the Windows\system32
> > folder where this dll resides.
> > What do you mean by other OCI client programs? Oracle client itself has
> > no troubles connecting to the database. Also, 2083788472 doesn't look
> > like an Oracle error code? (Aren't they usually "ORA-XXXXX"?)
>Mark,
>I'm afraid I don't really know where to start. The error is very unusual
>as it is just the most basic initialization step, before even any attempt
>is made to contact the database or anything like that.
>Errors formatted by the Oracle error reporting functions normally start
>with ORA-, but in this case we don't even have error report services working
>yet, and so just have a raw 32bit integer status code.
>I read through the OCIEnvCreate() docs for Oracle 9 OCI and it does not
>give any clues about what might cause a failure.
>I really suspect it is some sort of runtime problem ... perhaps picking
>up the wrong oci shared library or something like that.
>I'm sorry I'm not more help.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | President OSGF, http://osgeo.org
