Problem with the mailinglist
Manfred Meier
m.meier at SPIEKERMANN.DE
Sat Jun 10 02:39:08 EDT 2006
in my mailbox this message showed up on Sat, 10. June 2006 at about
08:35 German time.
Friday was the 9th of June not the 8th. Was that a typo?
Manfred Meier
Christian Wilmes schrieb:
> Hi all,
> I've got some problems with this mailinglist. If I sent a mail to the list it takes hours or even days until it is in the list. If I try to sent a mail directly from the mailinglist homepage, after a few seconds I get the following mail:
> Rejected posting to MAPSERVER-USERS at LISTS.UMN.EDU
> Your message is being returned to you unprocessed because it appears to have already been distributed to the MAPSERVER-USERS list. That is, a message with identical text (but possibly with different mail headers) has been posted to the list recently, either by you or by someone else. If you have reason to resend this message to the list (for instance because you have been notified of a hardware failure with loss of data), please alter the text of the message in some way and resend it to the list. Note that altering the "Subject:" line or adding blank lines at the top or bottom of the message is not sufficient; you should instead add a sentence or two at the top explaining why you are
> resending the message, so that the other subscribers understand why they are getting two copies of the same message.
> Because of these things it happens in the last time, that I was sending a mail more than one time, sorry for that!
> I hope someone who is responsible for the mailinglist will read this mail and is probatly able to help me.
> This mail for example I will send at on Friday 08.06.2006 at 11:20am German time....wonder how long it will take this time until the mail is in the list.
> Best Regards
> Christian
