Problem with the mailinglist
Manfred Meier m.meier at SPIEKERMANN.DE
Mon Jun 12 04:08:43 EDT 2006
I received this message on Monday 12, 10:00 German time. Not bad!
A long time ago, when I did subscribe to the list there was an option to
get all mails bundled once a day. Can this be the problem in your case?
Greetings
Manfred Meier
Christian Wilmes schrieb:
>>sorry, you are right, of course it was the 9th of June. I can't see any regularity for the delay, it just seems to be chance.
> So where do I have to search the problem? It seems nobody else have the same problems, so could it be a problem of my mail-provider (gmx.de)?
> This message was sent on Monday the 12th of june at 09:53am german time.
> Best Regards
> Christian
> -------- Original-Nachricht --------
>> Datum: Sat, 10 Jun 2006 08:39:08 +0200
>> Von: Manfred Meier <m.meier at SPIEKERMANN.DE>
>> An: MAPSERVER-USERS at LISTS.UMN.EDU
>> Betreff: Re: [UMN_MAPSERVER-USERS] Problem with the mailinglist
>> &#xA> Hi,
>>in my mailbox this message showed up on Sat, 10. June 2006 at about
>>08:35 German time.
>>Friday was the 9th of June not the 8th. Was that a typo?
>>Manfred Meier
>>>Hi all,
>>>I've got some problems with this mailinglist. If I sent a mail to the
>>list it takes hours or even days until it is in the list. If I try to sent
>>a mail directly from the mailinglist homepage, after a few seconds I get
>>the following mail:
>>>Rejected posting to MAPSERVER-USERS at LISTS.UMN.EDU
>>>Your message  is being returned to  you unprocessed because it  appears
>>to have already been distributed  to the MAPSERVER-USERS list. That is,  a
>>message with identical text  (but possibly with different  mail headers)
>>has been  posted to the list  recently, either by  you or  by someone
>>else.
>> If you have  reason to resend this message to the list (for instance
>>because you have been notified of a hardware failure with loss of data),
>>please alter the text of the message in some way and resend  it to the
>>list. Note that altering  the "Subject:" line or adding blank lines at
>>the
>>top or bottom of the message  is not sufficient; you should  instead add
>>a
>> sentence or  two  at  the top  explaining  why you  are
>>>resending the  message, so that the  other subscribers understand why
>>they are getting two copies of the same message.
>>>>Because of these things it happens in the last time, that I was
>>sending
>>a mail more than one time, sorry for that!
>>>>I hope someone who is responsible for the mailinglist will read this
>>mail and is probatly able to help me.
>>>This mail for example I will send at on Friday 08.06.2006 at 11:20am
>>German time....wonder how long it will take this time until the mail is in
>>the list.
>>>Best Regards
>>>Christian
