Problem with the mailinglist
Christian Wilmes
C.Wilmes at GMX.DE
Mon Jun 12 05:02:29 EDT 2006
>>That couldn't be the problem, I haven't choose that option. But the last time it seems to work. I get my own message at 9:59.
So hoping I've got luck again and this message will be in the list in a few minutes too.
Mo 11:02 am German Time.
-------- Original-Nachricht --------
> Datum: Mon, 12 Jun 2006 10:08:43 +0200
> Von: Manfred Meier <m.meier at SPIEKERMANN.DE>
> An: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] Problem with the mailinglist
> Hi,
> I received this message on Monday 12, 10:00 German time. Not bad!
> A long time ago, when I did subscribe to the list there was an option to
> get all mails bundled once a day. Can this be the problem in your case?
> Greetings
> Manfred Meier
> Christian Wilmes schrieb:
> >>sorry, you are right, of course it was the 9th of June. I can't see any
> regularity for the delay, it just seems to be chance.
> > > So where do I have to search the problem? It seems nobody else have
> the
> same problems, so could it be a problem of my mail-provider (gmx.de)?
> > This message was sent on Monday the 12th of june at 09:53am german time.
> > Best Regards
> > Christian
> >> Datum: Sat, 10 Jun 2006 08:39:08 +0200
> Hi,
> >>in my mailbox this message showed up on Sat, 10. June 2006 at about
> >>08:35 German time.
> >>Friday was the 9th of June not the 8th. Was that a typo?
> >>Manfred Meier
> >>>Hi all,
> >>>I've got some problems with this mailinglist. If I sent a mail to the
> >>list it takes hours or even days until it is in the list. If I try to
> sent
> >>a mail directly from the mailinglist homepage, after a few seconds I get
> >>the following mail:
> >>>Rejected posting to MAPSERVER-USERS at LISTS.UMN.EDU
> >>>Your message is being returned to you unprocessed because it appears
> >>to have already been distributed to the MAPSERVER-USERS list. That is,
> a
> >>message with identical text (but possibly with different mail headers)
> >>has been posted to the list recently, either by you or by someone
> >>else.
> >> If you have reason to resend this message to the list (for instance
> >>because you have been notified of a hardware failure with loss of data),
> >>please alter the text of the message in some way and resend it to the
> >>list. Note that altering the "Subject:" line or adding blank lines at
> >>the
> >>top or bottom of the message is not sufficient; you should instead add
> >>a
> >> sentence or two at the top explaining why you are
> >>>resending the message, so that the other subscribers understand why
> >>they are getting two copies of the same message.
> >>>>Because of these things it happens in the last time, that I was
> >>sending
> >>a mail more than one time, sorry for that!
> >>>>I hope someone who is responsible for the mailinglist will read this
> >>mail and is probatly able to help me.
> >>>This mail for example I will send at on Friday 08.06.2006 at 11:20am
> >>German time....wonder how long it will take this time until the mail is
> in
> >>the list.
> >>>Best Regards
> >>>Christian
"Feel free" – 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
