Mapscript ,Mono, Apache and Linux : a great story
Xavier Mauclaire
xavier.mauclaire at GEOTER.FR
Tue Jun 13 03:44:04 EDT 2006
HI
I'm developping a web site using Mono (1.1.13) Apache (2.0.54) MApscript
(4.8.3). I'm using Vs2003 to develop and linux as deployement platform.
All works well with windows but on linux i get the folowing error in th
error_log apache file and the web server shutdowns.
Any help well be appreciated. I don't know what to do
regards
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Stacktrace:
in (wrapper managed-to-native) mapscriptPINVOKE:layerObj_getFeature
(System.Runtime.InteropServices.HandleRef,int,int) <0x4>
(System.Runtime.InteropServices.HandleRef,int,int) <0xffffff87>
in layerObj:getFeature (int,int) <0x27>
in siteflash.GetParcelleReglement:localiser_parcelle (double,double,string&)
<0x1ca>
in siteflash.GetParcelleReglement:ProcessRequest (System.Web.HttpContext)
<0x56c>
in <Pipeline>__1:MoveNext () <0x10a0>
in System.Web.HttpApplication:Tick () <0x1f>
in System.Web.HttpApplication:Start (object) <0x37>
in
System.Web.HttpApplication:System.Web.IHttpAsyncHandler.BeginProcessRequest
(System.Web.HttpContext,System.AsyncCallback,object) <0x68>
in System.Web.HttpRuntime:RealProcessRequest (object) <0x1ab>
in System.Web.HttpRuntime:ProcessRequest (System.Web.HttpWorkerRequest)
<0x2c>
in Mono.WebServer.MonoWorkerRequest:ProcessRequest () <0xa>
in Mono.WebServer.BaseApplicationHost:ProcessRequest
(Mono.WebServer.MonoWorkerRequest) <0x43>
in Mono.WebServer.ModMonoApplicationHost:ProcessRequest
(int,string,string,string,string,string,int,string,int,string,string[],strin
g[]) <0xdc>
in (wrapper remoting-invoke-with-check)
g[]) <0xffffff0a>
in (wrapper xdomain-dispatch)
(object,byte[]&,byte[]&,int,string,string,string,string,string,int,string,in
t,string,string[],string[]) <0xffeecda6>
in (wrapper xdomain-invoke)
g[]) <0xffffff6a>
g[]) <0xffca7c74>
in Mono.WebServer.ModMonoWorker:InnerRun (object) <0x404>
in Mono.WebServer.ModMonoWorker:Run (object) <0x17>
in (wrapper delegate-invoke) System.MulticastDelegate:invoke_void_object
(object) <0xffffff95>
in (wrapper runtime-invoke) System.Object:runtime_invoke_void_object
(object,intptr,intptr,intptr) <0xc74b289f>
Native stacktrace:
/usr/lib/pkgconfig/../../bin/mono(mono_handle_native_sigsegv+0xbb)
[0x814ee2b]
/usr/lib/pkgconfig/../../bin/mono [0x813b2cf]
[0xffffe440]
/lib/tls/libc.so.6(malloc+0x86) [0x40187ea6]
/usr/local/lib/libmapscript.so(strstrIgnoreCase+0x47) [0x417f8fd7]
/usr/local/lib/libmapscript.so [0x417f90e4]
/usr/local/lib/libmapscript.so(msPOSTGISLayerGetShape+0x7d) [0x417f973d]
/usr/local/lib/libmapscript.so(msPOSTGISLayerGetShapeVT+0x23) [0x417f9e93]
/usr/local/lib/libmapscript.so(msLayerGetShape+0x2e) [0x417a8d6e]
/usr/local/lib/libmapscript.so(CSharp_layerObj_getFeature+0x46)
[0x41764766]
[0x41721a9a]
[0x417219b8]
[0x41720b93]
[0x4172023d]
[0x415b64f9]
[0x415b5380]
[0x415b1768]
[0x415b1649]
[0x411111f4]
[0x41110d25]
[0x41110ce3]
[0x4111029c]
[0x410f54e5]
[0x410f4c4c]
[0x410f4a2b]
[0x40fe14bf]
[0x40fe12fb]
[0x40c88e9d]
[0x40c889f0]
[0x40c889b4]
[0x40c8890e]
/usr/lib/pkgconfig/../../bin/mono [0x813b180]
/usr/lib/pkgconfig/../../bin/mono(mono_runtime_invoke+0x27) [0x80d63f7]
/usr/lib/pkgconfig/../../bin/mono(mono_runtime_invoke_array+0x270)
[0x80d78c0]
/usr/lib/pkgconfig/../../bin/mono(mono_message_invoke+0xc5) [0x80d93d5]
/usr/lib/pkgconfig/../../bin/mono [0x80a509f]
/usr/lib/pkgconfig/../../bin/mono [0x80a58c9]
/usr/lib/pkgconfig/../../bin/mono [0x8099fb2]
/usr/lib/pkgconfig/../../bin/mono [0x80f5067]
/usr/lib/pkgconfig/../../bin/mono [0x8113175]
/lib/tls/libpthread.so.0 [0x400e5297]
/lib/tls/libc.so.6(__clone+0x5e) [0x401e037e]
[Tue Jun 13 17:45:12 2006] [notice] caught SIGTERM, shutting down
[Tue Jun 13 17:45:21 2006] [warn] module mono_module is already loaded,
skipping
[Tue Jun 13 17:45:22 2006] [notice] Apache/2.0.54 (Linux/SUSE) configured --
resuming normal operations
Another mod-mono-server with the same arguments is already running.
[Tue Jun 13 17:53:44 2006] [notice] caught SIGTERM, shutting down
Xavier Mauclaire
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060613/92bbcff1/attachment.html
