Anti Alias Problem
Thomas Hammerlund tom at MAPLINK.JP
Wed Jun 14 20:52:34 EDT 2006
Thank you Umberto, I'll try the patch.
----- Original Message -----
From: "Umberto Nicoletti" <umberto.nicoletti at gmail.com>
To: "Thomas Hammerlund" <tom at maplink.jp>
Cc: <MAPSERVER-USERS at lists.umn.edu>
Sent: Wednesday, June 14, 2006 5:12 PM
Subject: Re: [UMN_MAPSERVER-USERS] Anti Alias Problem
> On 6/14/06, Thomas Hammerlund <tom at maplink.jp> wrote:
>> Thank you for your reply Steve.
>> I'm running mapserver 4.8.3 and outputting jpegs via the gdal/jpeg
>> driver.
>> I'm using the gdal driver because the gd/jpeg driver output progressive
>> encoded jpegs(which i couldn't use).
>> Example layer:
>> LAYER
>>   NAME l_koku_u
>>   STATUS ON
>>   TILEINDEX "ixs/shb/50000/l_koku_u_ix"
>>   TILEITEM "location"
>>   TYPE LINE
>>   CLASSITEM Code
>> CLASS
>>  MAXSCALE 337000
>>  MINSCALE 85001
>>  Name style1
>>  EXPRESSION 'l_bbbcd'
>>     STYLE
>>       COLOR 240 184 53
>>       WIDTH 1
>>            #ANTIALIAS TRUE
>>     END
>>   END
>> END
>> I'm creating my image using perl mapscript.  my mistake, the problem is
>> not
>> with the fonts but with the lines.  when I turn style antialiasing on for
>> my
>> line layers perl throws an internal server error with no error message
>> from
>> mapserver (or perl).
>> The outputformat in my mapfile looks like this:
>> OUTPUTFORMAT
>> NAME jpeg
>> DRIVER "GDAL/JPEG"
>> MIMETYPE "image/jpeg"
>>  IMAGEMODE RGB
>> FORMATOPTION "QUALITY=100"
>>  EXTENSION "jpg"
>> END
>> Which antialias patch are you referring to?
> This one (against gd-2.0.33):
> *** gd.c.orig   Wed Jun 14 10:06:22 2006
> --- gd.c        Mon Jun 12 12:05:28 2006
> *** 3032,3037 ****
> --- 3032,3040 ----
>  static void gdImageSetAAPixelColor(gdImagePtr im, int x, int y, int
> color, int t)
>        int dr,dg,db,p,r,g,b;
> +       if(x<0||y<0||x>=im->sx||y>=im->sy) {
> +               return;
>        p = gdImageGetPixel(im,x,y);
>          /* TBB: we have to implement the dont_blend stuff to provide
>            the full feature set of the old implementation */
> or this one:
> http://lists.maptools.org/pipermail/ka-map-users/2006-March/001069.html
> The latter is probably better, as it uses a gd macro...
> HTH,
> Umberto
>> Thank you again,
>> Tom
>> From: "Steve Lime" <Steve.Lime at dnr.state.mn.us>
>> To: <MAPSERVER-USERS at LISTS.UMN.EDU>; <tom at MAPLINK.JP>
>> Sent: Wednesday, June 14, 2006 2:56 PM
>> > Hmmm... I'm suprised turning off style antialiasing would impact font
>> > antialiasing.
>> > They are totally unrelated.
>> > I guess we need a bit more information. What version of MapServer? Has
>> > the
>> > GD
>> > anti-aliasing patch been applied? What output image format?
>> > Steve
>> >>>> Thomas Hammerlund <tom at MAPLINK.JP> 06/13/06 1:03 AM >>>
>> > Hi Everyone,
>> > I've been looking for a solution to this, but haven't been successful
>> > so
>> > far
>> > so I'm hoping someone can help.
>> > I'm using Fedora 5, and everything I need is working great.  The
>> > problem
>> > is
>> > that when I try the same data set on Fedora 4 or Red Hat Advanced
>> > Server,
>> > anti alias doesn't work.  The problem can be resolved by commenting out
>> > the
>> > antialias line, but then it makes my font and lines look too choppy.
>> > Has
>> > anyone seen this?  Does anyone know if this is a Linux or a Mapserver
>> > problem?
>> > Thank you for your help,
>> > Tom
