MyGis connection question
John Prof jonnyprof at GMAIL.COM
Thu Jun 15 06:53:24 EDT 2006
Thaks again David,
I thought that was possible. I'd read the 'Ogr Direct Connection to Mysql'
page and I will use it.
I don't want to have shp, shx, dbf and duplicate database data to prevent
errors.
2006/6/15, Fawcett, David <David.Fawcett at state.mn.us>:
> John,
> My understanding is that MyGIS support has not been maintained in
> MapServer for a long time.  Recently, direct connection through OGR to MySQL
> for spatial support.
> Take a look at this page.
> David.
> -----Original Message-----
> From: UMN MapServer Users List on behalf of John Prof
> Sent: Wed 6/14/2006 10:50 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] MyGis connection question
> Hi David,
> I would prefer use the spatial extensions but I can't find nothing about.
> Your method works fine.
> Thanks
> 2006/6/13, Fawcett, David <David.Fawcett at state.mn.us >:
> >  John,
> > Take a look at this:  http://mapserver.gis.umn.edu/docs/howto/ogrmysql
> > You would need to change your data structure so that you store your x
> and
> > y values in separate columns.
> > Note that this method doesn't use MyGIS, it uses a direct connection
> > driver in OGR, so your MapServer binary would need to be compiled with
> OGR
> > support (as most are).
> > David.
> > *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> *On
> > Behalf Of *John Prof
> > *Sent:* Tuesday, June 13, 2006 4:03 AM
> > *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> > *Subject:* [UMN_MAPSERVER-USERS] MyGis connection question
> > Hello,
> > I'm trying to connect mapserver's map with a mysql datatable like this:
> > id                            int
> > name                      varchar(20)
> > description              varchar(100)
> > location                  point
> > I'd like to create a shape with the points and the labels of the name.
> Is
> > it possible? I've tried many ways but I have errors.
> > I'd like to do something like this example:
> > LAYER
> > CONNECTIONTYPE mygis
> > NAME "City"
> > CONNECTION "host:user:passwd:database:bin"
> > DATA "location from city"
> > TYPE POINT
> > STATUS ON
> > END
> > It fails. I've tried with some mysql functions like AsBinary(point), but
> > it doesn't work.
> > I must use sh2mysql structure to store data in my database? Is not
> > possible make my simply case?
> > Thanks and sorry for my english :p
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060615/b34839a2/attachment.html
