MyGis connection question
    John Prof
    jonnyprof at GMAIL.COM
    Wed Jun 14 08:50:28 PDT 2006
Hi David,
I would prefer use the spatial extensions but I can't find nothing about.
Your method works fine.
Thanks
2006/6/13, Fawcett, David <David.Fawcett at state.mn.us >:
>  John,
> Take a look at this:  http://mapserver.gis.umn.edu/docs/howto/ogrmysql
> You would need to change your data structure so that you store your x and
> y values in separate columns.
> Note that this method doesn't use MyGIS, it uses a direct connection
> driver in OGR, so your MapServer binary would need to be compiled with OGR
> support (as most are).
> David.
>  -----Original Message-----
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *John Prof
> *Sent:* Tuesday, June 13, 2006 4:03 AM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* [UMN_MAPSERVER-USERS] MyGis connection question
> Hello,
> I'm trying to connect mapserver's map with a mysql datatable like this:
> id                            int
> name                      varchar(20)
> description              varchar(100)
> location                  point
> I'd like to create a shape with the points and the labels of the name. Is
> it possible? I've tried many ways but I have errors.
> I'd like to do something like this example:
> LAYER
> CONNECTIONTYPE mygis
> NAME "City"
> CONNECTION "host:user:passwd:database:bin"
> DATA "location from city"
> TYPE POINT
> STATUS ON
> END
> It fails. I've tried with some mysql functions like AsBinary(point), but
> it doesn't work.
> I must use sh2mysql structure to store data in my database? Is not
> possible make my simply case?
> Thanks and sorry for my english :p
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060614/7a2dcb98/attachment.htm>
More information about the MapServer-users
