oracle spatial
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Fri Jun 16 09:09:02 EDT 2006
It sounds like an oracle10g libmap.dll build problem, and not your
fault. checking into it. Until this is solved, if you need an Oracle
connection you will have to use MS4W 1.5.3
(http://www.maptools.org/dl/ms4w/ms4w_1.5.3.zip), sorry.
jeff
Zhonghai Wang wrote:
> Hi there,
> I am now facing the same problem now, after the DLL swapping according
> to the read-me file, the other old MapServer projects do not work any
> more, even under the CGI mode, and the error message looks like:
> [Fri Jun 16 14:38:55 2006] [error] [client 127.0.0.1 <http://127.0.0.1>]
> Premature end of script headers: mapserv.exe -- this is the error
> message in the Apache error log file.
> do anyone have any ideas?
> BTW: my system info: WinXP, MS4W 2.0, Oracle 10g R2 Instant Client
> the ogrinfo --formats that OCI is supported.
> many thanks.
> zhonghai
> On 6/16/06, *Lasse Korhonen* <lasse.korhonen at kokkola.fi
> <mailto:lasse.korhonen at kokkola.fi>> wrote:
> Hi Daniel,
> we're facing exactly the same problems you described. Swapping of
> dll-files
> is enough to make previously working maps totally unfunctional. Maps
> based
> on oracle spatial, shapefiles or MapInfo-files all give an Apache
> related
> message "Internal Server Error". Last row in the error.log states
> "Premature
> end of script headers: mapserv.exe".
> I can get errors from MapServer if I break the syntax in map-file, and
> mistakes in SQL-statements raise errors from Oracle (connection is
> fine?).
> Therefore I believe the problem is not related to .map-files or
> database at
> all.
> I'm wondering if this strange behaviour is somehow related to "wrong"
> software environment. So far we have tested following combinations
> with no
> luck:
> MS4W v1.5.4 & Windows NT 4.0 & remote Oracle 10g R2 database
> MS4W v2.0 & Windows NT 4.0 & remote Oracle 10g R2 database
> MS4W v1.5.4 & Windows 2003 Server & local Oracle 10g R2 database
> Maybe Jukka could tell what operating system he had in his successful
> installation?
> http://www.nabble.com/oracle-spatial-t1774461.html#a4895493
> Sent from the Mapserver - User forum at Nabble.com <http://Nabble.com>.
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
