[UMN_MAPSERVER-USERS] oracle spatial
Fortin,Nicolas [SteFoy]
nicolas.fortin at EC.GC.CA
Fri Jun 16 09:20:57 EDT 2006
I use Oracle10g but neither MS4W nor Apache. I use IIS and my own compilation of mapserver.
Windows XP SP2
IIS 5.1
Mapserver 4.8.3 CVS from 2006-06-07
Oracle 10g 10.1.0.2
All works fine.
Nicolas
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Rahkonen Jukka
Envoyé : 16 juin 2006 09:11
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] oracle spatial
I have Oracle 9i and I have faced no problem. Any happy 10g users out there?
-Jukka-
Lähettäjä: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Puolesta Zhonghai Wang
Lähetetty: 16. kesäkuuta 2006 15:43
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: Re: [UMN_MAPSERVER-USERS] oracle spatial
Hi there,
I am now facing the same problem now, after the DLL swapping according to the read-me file, the other old MapServer projects do not work any more, even under the CGI mode, and the error message looks like:
[Fri Jun 16 14:38:55 2006] [error] [client 127.0.0.1] Premature end of script headers: mapserv.exe -- this is the error message in the Apache error log file.
do anyone have any ideas?
BTW: my system info: WinXP, MS4W 2.0, Oracle 10g R2 Instant Client
the ogrinfo --formats that OCI is supported.
many thanks.
zhonghai
On 6/16/06, Lasse Korhonen <lasse.korhonen at kokkola.fi> wrote:
Hi Daniel,
we're facing exactly the same problems you described. Swapping of dll-files
is enough to make previously working maps totally unfunctional. Maps based
on oracle spatial, shapefiles or MapInfo-files all give an Apache related
message "Internal Server Error". Last row in the error.log states "Premature
end of script headers: mapserv.exe".
I can get errors from MapServer if I break the syntax in map-file, and
mistakes in SQL-statements raise errors from Oracle (connection is fine?).
Therefore I believe the problem is not related to .map-files or database at
all.
I'm wondering if this strange behaviour is somehow related to "wrong"
software environment. So far we have tested following combinations with no
luck:
MS4W v1.5.4 & Windows NT 4.0 & remote Oracle 10g R2 database
MS4W v2.0 & Windows NT 4.0 & remote Oracle 10g R2 database
MS4W v1.5.4 & Windows 2003 Server & local Oracle 10g R2 database
Maybe Jukka could tell what operating system he had in his successful
installation?
View this message in context: http://www.nabble.com/oracle-spatial-t1774461.html#a4895493
Sent from the Mapserver - User forum at Nabble.com.
