[UMN_MAPSERVER-USERS] oracle spatial
Zhonghai Wang
zhonghaiw at GMAIL.COM
Fri Jun 16 10:09:09 EDT 2006
Hi Jeff,
thanks you for your feedback.
I tried with the command shp2img, both CONNECTTYPEs work well: OracleSpaital
and OCI, the error only occurs with the HTTP request--I am using the CGI
mode:
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/Demo/OracleTest.map&mode=map
hope this helps to find out the problem.
thanks again, I will try it with MS4W 1.5.3.
zhonghai
On 6/16/06, Fortin,Nicolas [SteFoy] <nicolas.fortin at ec.gc.ca> wrote:
> I use Oracle10g but neither MS4W nor Apache. I use IIS and my own
> compilation of mapserver.
> Windows XP SP2
> IIS 5.1
> Mapserver 4.8.3 CVS from 2006-06-07
> Oracle 10g 10.1.0.2
> All works fine.
> Nicolas
> -----Message d'origine-----
> De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
> part de Rahkonen Jukka
> Envoyé : 16 juin 2006 09:11
> À : MAPSERVER-USERS at LISTS.UMN.EDU
> Objet : Re: [UMN_MAPSERVER-USERS] oracle spatial
> Hi,
> I have Oracle 9i and I have faced no problem. Any happy 10g users out
> there?
> -Jukka-
> Lähettäjä: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> Puolesta Zhonghai Wang
> Lähetetty: 16. kesäkuuta 2006 15:43
> Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
> Aihe: Re: [UMN_MAPSERVER-USERS] oracle spatial
> Hi there,
> I am now facing the same problem now, after the DLL swapping according to
> the read-me file, the other old MapServer projects do not work any more,
> even under the CGI mode, and the error message looks like:
> [Fri Jun 16 14:38:55 2006] [error] [client 127.0.0.1] Premature end of
> script headers: mapserv.exe -- this is the error message in the Apache
> error log file.
> do anyone have any ideas?
> BTW: my system info: WinXP, MS4W 2.0, Oracle 10g R2 Instant Client
> the ogrinfo --formats that OCI is supported.
> many thanks.
> zhonghai
> On 6/16/06, Lasse Korhonen <lasse.korhonen at kokkola.fi> wrote:
> Hi Daniel,
> we're facing exactly the same problems you described. Swapping of
> dll-files
> is enough to make previously working maps totally unfunctional. Maps based
> on oracle spatial, shapefiles or MapInfo-files all give an Apache related
> message "Internal Server Error". Last row in the error.log states
> "Premature
> end of script headers: mapserv.exe".
> I can get errors from MapServer if I break the syntax in map-file, and
> mistakes in SQL-statements raise errors from Oracle (connection is fine?).
> Therefore I believe the problem is not related to .map-files or database
> at
> all.
> I'm wondering if this strange behaviour is somehow related to "wrong"
> software environment. So far we have tested following combinations with no
> luck:
> MS4W v1.5.4 & Windows NT 4.0 & remote Oracle 10g R2 database
> MS4W v2.0 & Windows NT 4.0 & remote Oracle 10g R2 database
> MS4W v1.5.4 & Windows 2003 Server & local Oracle 10g R2 database
> Maybe Jukka could tell what operating system he had in his successful
> installation?
> http://www.nabble.com/oracle-spatial-t1774461.html#a4895493
> Sent from the Mapserver - User forum at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060616/7d43b7fa/attachment.html
