MapServer 4.x; GetFeatureInfo's SRS vs CRS
Arnaud Diederen
ad at IONICSOFT.COM
Fri Jun 16 11:08:23 EDT 2006
Hi again,
Arnaud Diederen wrote:
> Hi Tom,
> thank you for your reply!
> Kralidis,Tom [Burlington] wrote:
>> MapServer doesn't support WMS 1.3.0, only 1.1.1 1.0.0, and some in
>> between in ad hoc fashion.
>> You're GetFeatureInfo request cites version=1.3, where it should pass
>> 1.1.1. What happens if you send a request like:
>> http://localhost/cgi-bin/mapserv?map=/var/www/workshop/itasca.map&SRS=EP
>> SG:4326&BBOX=-99.30245,43.4354,-87.36445,49.404399999999995&TRANSPARENT=
>> TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=application/vnd.ogc.se_xml&WIDTH=800&HE
>> IGHT=400&LAYERS=airports&STYLES=&REQUEST=GetFeatureInfo&VERSION=1.1.1&SE
>> RVICE=WMS&INFO_FORMAT=gml&X=363&Y=121&FEATURE_COUNT=100&QUERY_LAYERS=air
>> ports
> It behaves exactly the same (the results with SRS and CRS are the same).
The same as before, I mean :)
SRS -> error
CRS -> ok
Regards,
Arnaud
> Regards,
> Arnaud
>> ..Tom
>>> Hello,
>>> When I issue a GetCapabilities on my installation of mapserver,
>>> using the following URL:
>>> sca.map&service=WMS&version=1.3&request=GetCapabilities
>>> I get a capabilities document showing:
>>> <WMT_MS_Capabilities version="1.1.1">
>>> So, the service expects requests of version 1.1.1 of the WMS spec,
>>> but when I issue a GetFeatureInfo with this URL:
>> map&SRS=EPSG:4326&BBOX=-99.30245,43.4354,-87.36445,49.404399999999995&TR
>> ANSPARENT=TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=application/vnd.ogc.se_xml&WI
>> DTH=800&HEIGHT=400&LAYERS=airports&STYLES=&REQUEST=GetFeatureInfo&VERSIO
>> N=1.3&SERVICE=WMS&INFO_FORMAT=gml&X=363&Y=121&FEATURE_COUNT=100&QUERY_LA
>> YERS=airports
>> I get the following error:
>> <ServiceExceptionReport version="1.1.1">
>> <ServiceException code="InvalidSRS">
>> msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS
>> must be valid for all requested layers.
>> </ServiceException>
>> </ServiceExceptionReport>
>> hmm. But then, if I change the SRS parameter name to CRS, I get a
>> valid (though empty) result:
>> <msGMLOutput
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> </msGMLOutput>
>> The weird thing is that in the version 1.1.1 of the spec, there is no
>> CRS parameter for the GetFeatureInfo, but an SRS parameter. SRS was
>> changed to CRS at version 1.3.
>> It looks to me like a bug, am I wrong?
>> Best regards,
>> Arnaud
>> Last Minute Addendum: When I try with the equivalent (projected)
>> native logical bbox, in the native SRS (EPSG:26915, this is the
>> Itasca demo!) mapserver doesn't mind the name of the SRS param. Both
>> SRS and CRS work.
>> Now, I'm totally lost o_O
>> Will mapserver refuse to work properly if asked for features with a 4326
>> box?
>> Thanks for any information!
