MapServer 4.x; GetFeatureInfo's SRS vs CRS
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Jun 16 14:10:38 EDT 2006
Arnaud,
which SRS's are you advertizing in the MAP file? You need to advertize
them using WMS_SRS (or the more general OWS_SRS) metadata.
Can you post your current MAP file?
Best regards,
Bart
Arnaud Diederen wrote:
> Hello,
> When I issue a GetCapabilities on my installation of mapserver, using
> the following URL:
> http://localhost/cgi-bin/mapserv?map=/var/www/workshop/ita
> sca.map&service=WMS&version=1.3&request=GetCapabilities
> I get a capabilities document showing:
> <WMT_MS_Capabilities version="1.1.1">
> So, the service expects requests of version 1.1.1 of the WMS spec, but
> when I issue a GetFeatureInfo with this URL:
> http://localhost/cgi-bin/mapserv?map=/var/www/workshop/itasca.map&SRS=EPSG:4326&BBOX=-99.30245,43.4354,-87.36445,49.404399999999995&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=application/vnd.ogc.se_xml&WIDTH=800&HEIGHT=400&LAYERS=airports&STYLES=&REQUEST=GetFeatureInfo&VERSION=1.3&SERVICE=WMS&INFO_FORMAT=gml&X=363&Y=121&FEATURE_COUNT=100&QUERY_LAYERS=airports
> I get the following error:
> <ServiceExceptionReport version="1.1.1">
> <ServiceException code="InvalidSRS">
> msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS
> must be valid for all requested layers.
> </ServiceException>
> </ServiceExceptionReport>
> hmm. But then, if I change the SRS parameter name to CRS, I get a
> valid (though empty) result:
> <msGMLOutput
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> </msGMLOutput>
> The weird thing is that in the version 1.1.1 of the spec, there is no
> CRS parameter for the GetFeatureInfo, but an SRS parameter. SRS was
> changed to CRS at version 1.3.
> It looks to me like a bug, am I wrong?
> Best regards,
> Arnaud
> Last Minute Addendum: When I try with the equivalent (projected)
> native logical bbox, in the native SRS (EPSG:26915, this is the Itasca
> demo!) mapserver doesn't mind the name of the SRS param. Both SRS and
> CRS work. Now, I'm totally lost o_O
> Will mapserver refuse to work properly if asked for features with a
> 4326 box?
> Thanks for any information!
OSGIS, Open Source GIS
http://www.osgis.nl
