MapServer 4.x; GetFeatureInfo's SRS vs CRS
Arnaud Diederen
ad at IONICSOFT.COM
Mon Jun 19 03:25:13 EDT 2006
Hi Bart,
Bart van den Eijnden (OSGIS) wrote:
> Arnaud,
> which SRS's are you advertizing in the MAP file? You need to advertize
> them using WMS_SRS (or the more general OWS_SRS) metadata.
In the (attached) map file -a barely modified itasca.map from the demo-
I advertise epsg 26915, but I thought (erroneously) that the epsg 4326
would be supported as well.
Still, I found it funny that both CRS and SRS work for valid Epsg IDs,
and that SRS doesn't work for invalid Epsg IDs.
Regards,
Arnaud
> Can you post your current MAP file?
> Best regards,
> Bart
> Arnaud Diederen wrote:
>> Hello,
>> When I issue a GetCapabilities on my installation of mapserver, using
>> the following URL:
>> http://localhost/cgi-bin/mapserv?map=/var/www/workshop/ita
>> sca.map&service=WMS&version=1.3&request=GetCapabilities
>> I get a capabilities document showing:
>> <WMT_MS_Capabilities version="1.1.1">
>> So, the service expects requests of version 1.1.1 of the WMS spec,
>> but when I issue a GetFeatureInfo with this URL:
>> http://localhost/cgi-bin/mapserv?map=/var/www/workshop/itasca.map&SRS=EPSG:4326&BBOX=-99.30245,43.4354,-87.36445,49.404399999999995&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=application/vnd.ogc.se_xml&WIDTH=800&HEIGHT=400&LAYERS=airports&STYLES=&REQUEST=GetFeatureInfo&VERSION=1.3&SERVICE=WMS&INFO_FORMAT=gml&X=363&Y=121&FEATURE_COUNT=100&QUERY_LAYERS=airports
>> I get the following error:
>> <ServiceExceptionReport version="1.1.1">
>> <ServiceException code="InvalidSRS">
>> msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS
>> must be valid for all requested layers.
>> </ServiceException>
>> </ServiceExceptionReport>
>> hmm. But then, if I change the SRS parameter name to CRS, I get a
>> valid (though empty) result:
>> <msGMLOutput
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> </msGMLOutput>
>> The weird thing is that in the version 1.1.1 of the spec, there is no
>> CRS parameter for the GetFeatureInfo, but an SRS parameter. SRS was
>> changed to CRS at version 1.3.
>> It looks to me like a bug, am I wrong?
>> Best regards,
>> Arnaud
>> Last Minute Addendum: When I try with the equivalent (projected)
>> native logical bbox, in the native SRS (EPSG:26915, this is the
>> Itasca demo!) mapserver doesn't mind the name of the SRS param. Both
>> SRS and CRS work. Now, I'm totally lost o_O
>> Will mapserver refuse to work properly if asked for features with a
>> 4326 box?
>> Thanks for any information!
# Start of map file
MAP
NAME ITASCA
STATUS ON
SIZE 600 600
EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
TEMPLATEPATTERN "itasca"
IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter discussion
PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
"init=epsg:26915"
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
SYMBOL
NAME 'star'
TYPE VECTOR
FILLED TRUE
POINTS
0 .375
.35 .375
.5 0
.65 .375
1 .375
.75 .625
.875 1
.5 .75
.125 1
.25 .625
END
END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER templates/header.html
TEMPLATE "set in index.html"
FOOTER templates/footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in index.html"
IMAGEURL "set in index.html"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is a UMN MapServer application for Itasca County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS "none"
# change this value to match your setup
WMS_ONLINERESOURCE "http://localhost/cgi-bin/mapserv?map=/var/www/workshop/itasca.map"
WMS_SRS "EPSG:26915"
END
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.png
EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
SIZE 120 120
STATUS ON
MINBOXSIZE 5
MAXBOXSIZE 100
COLOR 255 0 0
OUTLINECOLOR 0 0 0
MARKERSIZE 8
MARKER 'star'
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS ON
END
# Start of layer definitions
LAYER
NAME drgs
TYPE RASTER
STATUS OFF
# OFFSITE 31
OFFSITE 252 252 252
CLASS
NAME 'Digital Raster Graphic'
KEYIMAGE graphics/drgs_keyimage.png
END
METADATA
WMS_TITLE "USGS 1:250,000 Digital Raster Graphic"
WMS_ABSTRACT "Hibbing and Bemidji quadrangles. See http://deli.dnr.state.mn.us/metadata/full/drgncim1.html for more information."
END
TILEINDEX drgidx
END
LAYER
NAME ctybdpy2
TYPE POLYGON
STATUS DEFAULT
DATA ctybdpy2
# no need for a background IF the USGS quads are being drawn
REQUIRES "![drgs]"
CLASSITEM 'cty_name'
CLASS
EXPRESSION 'Itasca'
STYLE
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
END
CLASS # every other county in the state
EXPRESSION /./
STYLE
COLOR 255 255 255
END
END
METADATA
WMS_TITLE "County Boundary"
WMS_ABSTRACT "Itasca County boundary shapefile. See http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for more information."
END
END
LAYER
NAME mcd90py2
GROUP cities
TYPE POLYGON
DATA mcd90py2
STATUS OFF
CLASSITEM city_name
CLASS
NAME "Cities & Towns"
EXPRESSION /./
STYLE
COLOR 255 225 90
END
TEMPLATE "templates/mcd90py2.html"
END
HEADER "templates/mcd90py2_header.html"
FOOTER "templates/mcd90py2_footer.html"
DUMP TRUE # allow GML export
METADATA
WMS_TITLE "Minor Civil Divisions"
WMS_ABSTRACT "Minor civil divisions for Itasca County (boundaries only)."
END
END
LAYER
NAME twprgpy3
TYPE POLYGON
DATA twprgpy3
STATUS OFF
CLASS
NAME 'Townships'
STYLE
SYMBOL 'circle'
SIZE 2
OUTLINECOLOR 181 181 145
END
END
METADATA
WMS_TITLE "Township Boundaries"
WMS_ABSTRACT "Pulic Land Survey (PLS) township boundaries for Itasca County. See http://deli.dnr.state.mn.us/metadata/full/twprgne2.html for more information."
END
END
LAYER
NAME lakespy2
TYPE POLYGON
STATUS OFF
DATA lakespy2
CLASS
NAME 'Lakes & Rivers'
TEMPLATE "templates/lakespy2.html"
STYLE
COLOR 49 117 185
END
END
HEADER "templates/lakespy2_header.html"
FOOTER "templates/lakespy2_footer.html"
TOLERANCE 3
METADATA
WMS_TITLE "Lakes and Rivers"
WMS_ABSTRACT "DLG lake and river polygons for Itasca County. See http://deli.dnr.state.mn.us/metadata/full/dlglkpy2.html for more information."
END
END # lakes
LAYER
NAME dlgstln2
TYPE LINE
STATUS OFF
DATA dlgstln2
CLASS
NAME "Streams"
TEMPLATE "templates/dlgstln2.html"
STYLE
COLOR 49 117 185
END
END
HEADER "templates/dlgstln2_header.html"
FOOTER "templates/dlgstln2_footer.html"
TOLERANCE 5
METADATA
WMS_TITLE "Streams"
WMS_ABSTRACT "DLG streams for Itasca County. See http://deli.dnr.state.mn.us/metadata/full/dlgstln2.html for more information."
END
END # streams
LAYER
NAME ctyrdln3
GROUP roads
MAXSCALE 300000
STATUS OFF
DATA ctyrdln3
TYPE LINE
CLASS
STYLE
COLOR 0 0 0
END
END
METADATA
WMS_TITLE "County Roads"
WMS_ABSTRACT "County roads (lines only). Derived from MNDOT roads layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more information."
END
END # county roads
LAYER
NAME ctyrdln3_anno
GROUP roads
MAXSCALE 300000
STATUS OFF
DATA ctyrdln3
TYPE ANNOTATION
LABELITEM "road_name"
CLASS
STYLE
COLOR 255 255 255
SYMBOL 'symbols/ctyhwy.png'
END
LABEL
MINFEATURESIZE 40
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
METADATA
WMS_ABSTRACT "County roads (shields only). Derived from MNDOT roads layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more information."
END
END # county road annotation
LAYER
NAME majrdln3
GROUP roads
MAXSCALE 600000
STATUS OFF
DATA majrdln3
TYPE LINE
CLASS
NAME "Roads"
STYLE
COLOR 0 0 0
END
END
METADATA
WMS_TITLE "Highways"
WMS_ABSTRACT "Highways- state, US and interstate (lines only). Derived from MNDOT roads layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more information."
END
END # highways
LAYER
NAME majrdln3_anno
GROUP roads
MAXSCALE 600000
STATUS OFF
DATA majrdln3
TYPE ANNOTATION
LABELITEM "road_num"
CLASSITEM "road_class"
CLASS
EXPRESSION "3"
STYLE
COLOR 0 0 0 # dummy color
SYMBOL 'symbols/sthwy.png'
END
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION "2"
STYLE
SYMBOL 'symbols/ushwy.png'
END
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION "1"
STYLE
SYMBOL 'symbols/interstate.png'
END
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 255 255 255
END
END
METADATA
WMS_ABSTRACT "Highways- state, US and interstate (shields only). Derived from MNDOT roads layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more information."
END
END # highway annotation
LAYER
NAME airports
TYPE POINT
DATA airports
STATUS OFF
CLASS
NAME 'Airports'
STYLE
COLOR 128 255 164
SYMBOL 'circle'
SIZE 7
END
TEMPLATE "templates/airports.html"
END
HEADER "templates/airports_header.html"
FOOTER "templates/airports_footer.html"
TOLERANCE 5
METADATA
WMS_TITLE "Airports"
WMS_ABSTRACT "Airport runways for Itasca County."
END
END
LAYER
NAME mcd90py2_anno
GROUP cities
TYPE ANNOTATION
DATA mcd90py2
STATUS OFF
LABELITEM "city_name"
CLASSITEM "city_name"
LABELMAXSCALE 500000
CLASS
EXPRESSION /./
LABEL
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS FALSE
BUFFER 2
END
END
METADATA
WMS_ABSTRACT "Minor civil divisions for Itasca County (annotation only)."
END
END
END # Map File
