Mapscript ,Mono, Apache and Linux : a great story
Xavier Mauclaire
xavier.mauclaire at GEOTER.FR
Thu Jun 22 12:07:04 EDT 2006
Good news tamas
I changed th ouput swf to png and got the same error
I don't test the program as console app yet.
You will find attached the error files
I installd mono from rpm package donwloaded from the mono site ans installed
them without taking yast dependencies message into considération. May this
installation mode the source of my problems ?
regards
Xavier Mauclaire
Service informatique
GEOTER SAS
3, rue Jean Monnet
34830 Clapiers France
Tél.: +33 (0)4.67.59.18.11
Fax: +33 (0)4.67.59.18.24
Email: xavier.mauclaire at geoter.fr
Web site: http://www.geoter.fr
-----Message d'origine-----
De : Tamas Szekeres [mailto:szekerest at gmail.com]
Envoyé : jeudi 22 juin 2006 16:54
À : Xavier Mauclaire
Cc : MAPSERVER-USERS at lists.umn.edu
Objet : Re: [UMN_MAPSERVER-USERS] Mapscript ,Mono, Apache and Linux : a
great story
Xavier,
I have tested your code under windows and linux and worked for me.
I have got: Nombre d'éléments 10
However on linux i did not want to bother with gdiplus.dll and friends so i
have rewritten the code as a console app that creates a new Form1 and
invokes the button1_Click().
And I have also switched to png instead of swf because i have not compiled
mapserver with SWF before.
Would you confirm that using it as a console app with png output makes crash
for you?
Would you post your exception information?
Thanks,
Tamas
2006/6/22, Xavier Mauclaire <xavier.mauclaire at geoter.fr>:
> Tamas
> This program has been created with VS2003. Under windows (.net) it
> works well.
> It has been compiled under linux with mono (file compile.sh) and
> tested under linux too. When running under linux it doesn't not work
> For the error you get, change, in the mapfile test.map the line
> IMAGETYPE swf By IMAGETYPE png
> Mapserver a been compiled with the swf option
> Do you want to have a chat on IRC?
> regards
> Xavier Mauclaire
> GEOTER SAS
> 3, rue Jean Monnet
> De : Tamas Szekeres [mailto:szekerest at gmail.com] Envoyé : jeudi 22
> juin 2006
> 13:53 À : Xavier Mauclaire Objet : Re: [UMN_MAPSERVER-USERS] Mapscript
> Hi Xavier,
> I 've tested on windows and i got:
> loadOutputFormat(): General error message. OUTPUTFORMAT clause
> references driver SWF, but this driver isn't configured. at
> mapObj..ctor(String filename)
> at Test1.Form1.button1_Click(Object sender, EventArgs e) in
> c:\cvs\xavier\test\test\form1.cs:line 124
> using your mapscript_csharp.dll. I am not so familiar with swf so give
> me some help.
> I am a bit confused whether you are tesing on windows or linux.
> regards,
> Tamas
> PS: I could not identify you on the mapserver IRC line :(
> > Hi tamas
> > You will find joined the file test.zip containing a little forms
> > programs using the mapserver getfeature function In the interface,
> > when you click on the button, the programs scratches like Mapserver.
> > You will notce that the code is not very clean (sorry).
> > Thre is another problem if i want to access séquentially to each
> > feature of a layer. If i use a while loop with testing the value of
> > the spaheObj returned by the function getfeature,this loop is
> > infinite because this function always returns a non NULL value. I
> > saw this problem
> with windows.
> > This is why i used a for loop.
> > regards
> > Xavier Mauclaire
> > GEOTER SAS
> > 3, rue Jean Monnet
> > juin 2006 00:45 À : 'Xavier Mauclaire'
> > Objet : RE: [UMN_MAPSERVER-USERS] Mapscript ,Mono, Apache and Linux :
> > a great story
> > I'm afraid i not understand exactly your application model. I am not
> > falmiliar with flash.
> > Could you explain the usage sequence in more detail and the steps to
> > test this problem?
> > I will trying look into it tomorrow then.
> > How should i configure apache for your app?
> > Tamas
> > -----Original Message-----
> > From: Xavier Mauclaire [mailto:xavier.mauclaire at geoter.fr]
> > Sent: Thursday, June 22, 2006 12:02 AM
> > To: 'Tamas Szekeres'
> > Subject: RE: [UMN_MAPSERVER-USERS] Mapscript ,Mono, Apache and Linux :
> > a great story
> > I'm going to use the dynamic layer so i'm going to update the source
> > what about installing the 4.6 version of mapserver on the linux server
> > The server scratches when i want to create a information form. This
> > form is launch by the flash program. It uses the web
> > getparcellereglement.aspx (client data(xml) are send using POST
> > method) This verb is managed by the GetParcelleReglement.cs class.
> > This class initializes mapserver and computes data. Finally it
> > redirects to parcellereglement.aspx to display informations.
> > I installed gaim to have discussion and i' connecting to the
> > mapserver forum. my alias is xavier34 regards
> > Xavier Mauclaire
> > Ingénieur Informaticien
> > GEOTER SAS
> > 3, rue Jean Monnet
> > De : Tamas Szekeres [mailto:szekerest at gmail.com] Envoyé : mercredi
> > 21 juin
> > 2006 23:37 À : 'Xavier Mauclaire'
> > a great story
> > >I did not include your code at this time because (if i understood
> > >your last email, the modification was about the dynamic creation of
> > >LayerObjet object.
> > >My last answer was about this. I wrote that i disabled the function
> > >to make a test and i prodcued the same error with the getfeature Do
> > >you want that i make the test?
> > >Most of the error are on the getfeature function but not all.
> > Xavier,
> > If you aren't using dynamically created layerObj classObj and
> > styleObj with a parent object given in the constructor that change
> > is not to be
> made.
> > >I get the problem when i'm connecting to the web site with my
> > >browser
> > You have several aspx files, what is the URL you are using?
> > >I can make an mono console application that create mapserver output
> > >file
> > and
> > >test the result
> > That would make the things much more easier.
> > Best Regards,
> > Tamas
> > No virus found in this outgoing message.
> > Checked by AVG Free Edition.
> > Version: 7.1.394 / Virus Database: 268.9.2/372 - Release Date:
2006.06.21.
> > No virus found in this incoming message.
2006.06.21.
2006.06.21.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060622/39fb902c/error.obj
