Mapserver/GD JPEGs
Blaise bpicinbono at WORLDONLINE.FR
Wed Jun 28 15:58:35 EDT 2006
Le Mardi 27 Juin 2006 08:35, Stephen Davies a écrit :
> Last week I posted a request regarding comments in JPEGs and their
> apparent effect on Motorola 3G telephones.
> Since then I have found that a) the issue seems to affect all WAP phones
> and b) it is not just comments that cause the problem.
> It seems that these devices can only handle very simple images and those
> generated by Mapserver/GD fall outside their capabilities.
> I have found that, as well as removing the comments from my map images,
> I have to go further.
> My current work-around is to use a PERL script to generate the map image
> to disk and then use the mogrify utility from Image Magik to "clean"
> it. The mogrify command is simply:
> but whatever this does to the image is enough to make it displayable on
> a telephone when sent as an img src=.
> If anybody knows more about what is happening here and/or what the
> underlying problem is, I would love to hear it.
> Cheers,
> Stephen Davies
Hi Stephen
Is it working ok with quality 100 jpeg images ? In this case, you could force
mapserver to create quality 100 jpeg images with the QUALITY parameter. Check
this doc :
http://mapserver.gis.umn.edu/docs/reference/mapfile/outputformat/
Regards
Blaise
