FW: [UMN_MAPSERVER-USERS] msLoadMap(): Unknown identifier.
Parsing error near (255):(line 4)
Albert Anderson
bart_doggers at YAHOO.COM
Thu Jun 29 10:47:24 EDT 2006
There is the my map file
#This is our first mapfile
NAME "First"
SIZE 400 300
IMAGETYPE 255 255 255
IMAGETYPE JPEG
SHAPEPATH "/home/mapdata/"
EXTENT -125.00 20.00 -65.00 50.00
WEB
TEMPLATE '/var/www/htdocs/first.html'
IMAGEPATH '/var/www/htdocs/tmp'
IMAGEURL '/tmp/'
END
LAYER
NAME "US States"
STATUS default
TYPE line
DATA "statesp020"
LABELITEM "STATE"
CLASS
STYLE
COLOR 0 0 0
END
COLOR 0 0 0
SIZE SMALL
END
END
END
END
and there is my html
<html>
<head><title>MapServer First Map</title></head>
<body>
<form method=POST action="/cgi-bin/mapserv">
<input type="submit" value="Click Me"
<input type="hidden" name="map"
value="/home/mapdata/first.map">
<input type="hidden" name="map_web_imagepath"
value="/var/www/htdocs/tmp/">
</form>
<IMG SRC="[img]" width=400 height=300 border=0>
</body>
</html>
Thanks,
Albert
"Fawcett, David" <David.Fawcett at STATE.MN.US> wrote:Message Albert,
Please CC' the entire list on your responses.
From your description, you have an error in your mapfile. I would suggest including the text of your mapfile in your response to the list.
David.
-----Original Message-----
From: Albert Anderson [mailto:bart_doggers at yahoo.com]
Sent: Thursday, June 29, 2006 9:13 AM
To: Fawcett, David
Subject: RE: [UMN_MAPSERVER-USERS] msLoadMap(): Unknown identifier. Parsing error near (255):(line 4)
I did a wapperscript and put name="map" in the html where the input is. Now I am getting this error msLoadMap(): Unknown identifier. Parsing error near (255):(line 4) . Could you please help me.
Thanks,
Albert
"Fawcett, David" <David.Fawcett at state.mn.us> wrote: Albert,
You are calling the MapServer cgi program, but you are not telling it which map file to use for configuration. If you are calling the program with a get request (in a URL), it should look something like:
http://my.site/cgi-bin/mapserv?map=/home/mydirectory/mymapfile.map
You will likely set other variables in the URL also, like mode, layers, etc.
If you are calling the MapServer cgi from a html form, you are missing a hidden html variable named map that, like the url variable above, would contain the path to your map file.
David.
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
Sent: Thursday, June 29, 2006 8:18 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] load Map error
I am getting this error loadMap(): Web application error. CGI variable "map" is not set. That is when I am clicking the submit button and it doesnt load up the map. Can anyone help me?
Thanks,
Albert
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1�/min.
Yahoo! Music Unlimited - Access over 1 million songs. Try it free.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060629/c0dfa5cf/attachment.html
