FW: [UMN_MAPSERVER-USERS] msLoadMap(): Unknown identifier.
Parsing error near (255):(line 4)
Fawcett, David
David.Fawcett at STATE.MN.US
Thu Jun 29 10:57:31 EDT 2006
Albert,
On line 4, you have 'IMAGETYPE 255 255 255'
This is causing the error. You should either comment this line out, or change it to 'IMAGECOLOR 255 255 255'
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
Sent: Thursday, June 29, 2006 9:47 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] FW: [UMN_MAPSERVER-USERS] msLoadMap(): Unknown identifier. Parsing error near (255):(line 4)
There is the my map file
#This is our first mapfile
NAME "First"
SIZE 400 300
IMAGETYPE JPEG
SHAPEPATH "/home/mapdata/"
EXTENT -125.00 20.00 -65.00 50.00
WEB
TEMPLATE '/var/www/htdocs/first.html'
IMAGEPATH '/var/www/htdocs/tmp'
IMAGEURL '/tmp/'
END
LAYER
NAME "US States"
STATUS default
TYPE line
DATA "statesp020"
LABELITEM "STATE"
CLASS
STYLE
COLOR 0 0 0
END
COLOR 0 0 0
SIZE SMALL
END
END
END
END
and there is my html
<html>
<head><title>MapServer First Map</title></head>
<body>
<form method=POST action="/cgi-bin/mapserv">
<input type="submit" value="Click Me"
<input type="hidden" name="map"
value="/home/mapdata/first.map">
<input type="hidden" name="map_web_imagepath"
value="/var/www/htdocs/tmp/">
</form>
<IMG SRC="[img]" width=400 height=300 border=0>
</body>
</html>
Thanks,
Albert
"Fawcett, David" <David.Fawcett at STATE.MN.US> wrote:
Albert,
Please CC' the entire list on your responses.
From your description, you have an error in your mapfile. I would suggest including the text of your mapfile in your response to the list.
David.
From: Albert Anderson [mailto:bart_doggers at yahoo.com]
Sent: Thursday, June 29, 2006 9:13 AM
To: Fawcett, David
Subject: RE: [UMN_MAPSERVER-USERS] msLoadMap(): Unknown identifier. Parsing error near (255):(line 4)
I did a wapperscript and put name="map" in the html where the input is. Now I am getting this error msLoadMap(): Unknown identifier. Parsing error near (255):(line 4) . Could you please help me.
Thanks,
Albert
"Fawcett, David" <David.Fawcett at state.mn.us> wrote:
Albert,
You are calling the MapServer cgi program, but you are not telling it which map file to use for configuration. If you are calling the program with a get request (in a URL), it should look something like:
http://my.site/cgi-bin/mapserv?map=/home/mydirectory/mymapfile.map
You will likely set other variables in the URL also, like mode, layers, etc.
If you are calling the MapServer cgi from a html form, you are missing a hidden html variable named map that, like the url variable above, would contain the path to your map file.
David.
Sent: Thursday, June 29, 2006 8:18 AM
Subject: [UMN_MAPSERVER-USERS] load Map error
I am getting this error loadMap(): Web application error. CGI variable "map" is not set. That is when I am clicking the submit button and it doesnt load up the map. Can anyone help me?
Thanks,
Albert
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1�/min. <http://us.rd.yahoo.com/mail_us/taglines/postman7/*http://us.rd.yahoo.com/evt=39666/*http://messenger.yahoo.com>
Yahoo! Music Unlimited - Access over 1 million songs. Try it free. <http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=36035/*http://music.yahoo.com/unlimited/%20>
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060629/1347320e/attachment.html
