PERL interface trouble
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Jun 29 15:56:06 EDT 2006
Hi Joe,
A couple of things.
1) what version does you existing code work on?
2) There are probably two areas that you will need to change
a) the mapfile
b) the perl
I would start with using shp2img to make sure you mapfile can load. It
will at least print errors that you can read.
shp2img -m /path/to/file.map -o junk.png ...
Once you can get an image then you will probably have more luck tracking
down the various mapscript changes. These will depend on what version of
mapscript your code was written for.
-Steve W.
Joseph Bussell wrote:
> Greetings Listers,
> It has been a while since I deployed a new Mapserver application. I
> have been leaning on old source on an old box to get the work done. I
> have been given a new server to set up for our Air Force project and
> have had some issues with getting my code to work. First of all I am
> using Mapscript ala PERL. I recognize that the PERL interface has not
> been updated due to a lack of user interest, but I am still partial to
> using it if it can still be done (mostly since I will not have to
> rewrite my routing path functionality).
> My problem is getting the actual mapObj to construct from my mapfile.
> I have not been able to get any debug information our by checking
> /tmp/mserrors, which used to work nicely in such cases. All I get is an
> undefined reference. My code for construction is simple:
> my $map = new mapscript::mapObj( $mapfile ) or carp "Could not create
> mapscript object from mapfile: $mapfile";
> in my httpd.conf I define
> MS_ERRORFILE /tmp/mserrors.txt
> My mapfile exists and is very simple.
> I am running:
> CentOS release 4.3
> AMD64, dual core machine
> Apache/2.0.52
> mapserver-4.8.3.tar.gz
> perl, v5.8.5 built for x86_64-linux-thread-multi
> Thank you for your time.
> Joe Bussell
> On Time Systems
