MapServer 4.8.3 and ArcSDE 8.3
Mike Saunt
mikesaunt at GMAIL.COM
Fri Jun 30 03:15:55 EDT 2006
Many thanks Brock and Norbert
I will check with the client re what API version they have (they have ArcGIS
9.1) - I am presuming that the C API Client DLL's are supplied as standard
by ESRI UK.
I'll keep you all in the loop.
Cheers
Mike
On 29/06/06, Brock Anderson <banders at refractions.net> wrote:
> Mike,
> I use a slightly older version of Mapserver against ArcSDE 8.3 and
> ArcSDE 9. (I believe the ArcSDE 9.x C API works with 8.3 as well.) I'm
> fairly sure the latest MS4W will connect to ArcSDE 8.3.
> Brock
> Mike Saunt wrote:
> > Hi All
> > Wondering if anyone can help. I have a client who is running ArcSDE
> > 8.3 on Oracle and we want to connect MapServer 4.8.3 (via the pre
> > compiled Windows binaries from MS4W and using the libmap for sde) to
> > this instance of ArcSDE. We've downloaded the ArcSDE C API client
> > library but won't be able to test until on site - was hoping someone
> > may have had this backward version exepreince with ArcSDE
> > Anyone aware of any issues?
> > Many Thanks in advance
> > Mike
> > PS - I've been doing some testing here with MapServer over MapInfo
> > MapXtreme.NET. MapServer wins hands down even reading MapInfo TAB!
> > Well done to all involved.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060630/65ade5a9/attachment.html
