Image tilling
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Fri Jun 30 16:09:52 EDT 2006
What I am trying to do is to georeference aerial photos of a large area,
eventually the entire earth. So what I need is to be able to specify the
lat/long of each photo (which I have) using only the lat/long coordinate
system. I would like the user to be able to specify a bounding box (lat/long)
for a given area then have my mapserver return all the available images for
that given area. Currently I think that I can use:
gdal_translate -a_ullr 180 0 210 -30 thm_dir_N-30_180.png thm_dir_N-30_180.tiff
To georeference all of my photos, then:
gdaltindex thm_dir.shp *.tif
To create a shape file with an index of all the photos, then I can specify my
layer in the mapfile as:
LAYER
NAME "tileindex"
STATUS ON
TILEINDEX "thm_dir.shp"
TILEITEM "Location"
TYPE RASTER
END
But when I display this layer in MapServer I get a blank image, and when I try
to view the shape file in ArcMap I can see my tiles but they are just displayed
as blank polygons with no images. I think that my problem is incorrectly
specifying the EXTENT in the map file, but i am not sure what i should put if i
want my tiles to eventually cover then entire world.
Thanks,
-Ryan
Here is my entire map file incase that helps any:
NAME WMSDEMO
STATUS ON
SIZE 500 400
#EXTENT 0 0 2800 2800
#EXTENT -180 -90 180 90
EXTENT -9200000 -912631 3072800 3840000
#UNITS METERS
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
WEB
TEMPLATE test_template.html
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
WMS_TITLE "WMS test mapserver"
WMS_ACCESSCONSTRAINTS "none"
#WMS_ONLINERESOURCE "http://neuron/cgi-bin/mapserv?map=display.map&"
WMS_SRS "EPSG:4326" #"AUTO:42003"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER # Shaded Relief Raster
NAME test_layer
DATA bath_mapserver.tif
STATUS ON
TYPE RASTER
END
LAYER
NAME "hpool"
STATUS ON
#DATA "thm_dir_00_030.tiff"
#TILEITEM "Location"
TYPE RASTER
END
END # of map file
