Oracle Multitable Join
Fernando Simon fsimon at UNIVALI.BR
Wed Mar 1 19:58:35 EST 2006
Hi Christopher,
You can do this query using a DATA parameter like:
DATA "shape FROM (SELECT p.SHAPE, p.NAME FROM POINTS p, AREAS a WHERE
a.NAME = ‘California’ AND SDO_FILTER(p.shape, o.shape, ‘querytype =
WINDOW’) = ‘true’) USING NONE"
You can see more details about Oracle Spatial and Mapserver integration
in this link:
"http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto"
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Christopher Condit wrote:
> Is it possible to use multiple relations when adding an native oracle
> connection? I want to use something like this, but can’t quite figure
> out how:
> SELECT p.SHAPE, p.NAME FROM POINTS p, AREAS a WHERE a.NAME =
> ‘California’ AND SDO_FILTER(p.shape, o.shape, ‘querytype = WINDOW’) =
> ‘true’
> The idea is that I’ve got two Oracle spatial tables, one with points,
> the other with polygons. Given a polygon from the latter, I want all
> the points appearing in it to be drawn on the map. Is this possible
> with the existing Oracle spatial implementation? How would my DATA
> definition look?
> Thanks,
> Chris
