Oracle Spatial : Geodetic data : queries fail
Fernando Simon
fsimon at UNIVALI.BR
Thu Mar 2 12:14:38 EST 2006
Hi Michael,
For 9i version you can use the VERSION parameter in your layer DATA
definition, in your case:
DATA "SHAPE FROM SITE USING UNIQUE SITE_ID SRID 8307 RELATE
VERSION 9i"
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Michael Scharber wrote:
> Hi There,
> How exactly does one get MapServer to play with Geodetic data
> (SRID=8307) in Oracle Spatial (9i)? I cannot get past:
>> "Element of type Extent is not supported for Geodetic data"
>> msDrawMap(): Image handling error. Failed to draw layer named 'gps'.
>> msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
>> ORA-29902: error in executing ODCIIndexStart() routine ORA-13373:
>> Element of type Extent is not supported for Geodetic data ORA-06512:
>> at "MDSYS.SDO_INDEX_METHOD_9I", line 368 ORA-06512: at line 1 . Query
>> statement: SELECT SITE_ID, SHAPE FROM SITE WHERE SDO_RELATE( SHAPE,
>> MDSYS.SDO_GEOMETRY(2003, 8307,
>> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-8.94375,36.73125,13.55625,59.23125)
>> ),'mask=anyinteract querytype=window') = 'TRUE' . Check your data
>> statement
> For example, in other applications (Java, Perl, etc) I use the
> following with success:
> select site_code,site_name from site where
> SDO_RELATE(shape,MDSYS.SDO_GEOMETRY(2003,8307,null,
> MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),
> MDSYS.SDO_ORDINATE_ARRAY(-118.0,32.0,-116.0,32.0,-116.0,35.0,-118.0,35.0,-118.0,32.0)),
> 'mask=inside querytype=WINDOW') = 'TRUE'
> My MapServer config parameters are:
> CONNECTIONTYPE oraclespatial
> DATA "SHAPE FROM SITE USING UNIQUE SITE_ID SRID 8307 RELATE"
> Any suggestions?
> Thanks in advance.
> Michael
