C# mapscript...
Tamas Szekeres
szekeres.tamas at FREEMAIL.HU
Fri Mar 3 16:57:40 EST 2006
John,
The parser and lexer files are not precompiled with the CVS version. You
have at least 2 options to do:
1. Use the nightly build instead containing theese files precompiled
http://cvs.gis.umn.edu/dist/nightly.tar.gz
2. Download flex and bison
gnuwin32.sourceforge.net/packages/flex.htm
gnuwin32.sourceforge.net/packages/bison.htm
and generate theese files from mapparser.y and maplexer.l
Best Regards,
Tamas
On Fri, 3 Mar 2006 09:41:13 -0600, John Cole <john.cole at UAI.COM> wrote:
>Tamas,
> Starting into this and got the following compile error on mapservers
>Makefile.vc
>maputil.c(123) : fatal error C1083: Cannot open include file: 'mapparser.h':
>No
>such file or directory
>NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
>8\VC\BIN\c l.EXE"' : return code '0x2'
>Stop.
>I've downloaded rel-4-8-1 from cvs. Is there a file missing?
>Thanks,
>John Cole
>-----Original Message-----
>From: Tamas Szekeres [mailto:szekeres.tamas at FREEMAIL.HU]
>Sent: Tuesday, February 28, 2006 2:54 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU; John Cole
>Subject: Re: C# mapscript...
>John,
>As far as I know precompiled binaries targeting the .NET framework 2.0 is
>not avaiable to download. However I suggest to compile one from the source.
>It is highly recommended to compile mapserver and mapscript with the same
>compiler version VS2005 in this case. You should enable only the options
>will be actually used in order to minimize the dependency from high number
>of libraries.
>Both of the current stable release (4.8.1) and the CVS version is known
>compilable
>with VS2005 with the following notes:
>1. Pre download and compile all of subsequent libraries to be used along
>with mapserver according to
>http://mapserver.gis.umn.edu/docs/howto/win32_compiling
>2. edit nmake.opt to enable the libraries
>3. Heck regex according to
>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1651
>4. To compile mapserver use Visual Studio 2005 Command Prompt issue
>nmake -f makefile.vc in the mapserver directory.
>5. To compile mapscript C# download swigwin-1.3.28 edit makefile.vc in the
>mapscript/csharp directory and give your swigwin path
>6. To eliminate high number of warnings you should define
>_CRT_SECURE_NO_DEPRECATE and _CRT_NONSTDC_NO_DEPRECATE like this:
>OPTFLAGS = /nologo /MD /Zi /D_CRT_SECURE_NO_DEPRECATE
>/D_CRT_NONSTDC_NO_DEPRECATE $(WARNING_LEVEL) $(DEBUG)
>7. If you are not using the CVS version modify owsrequest.i according to
>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1677
>8. Use nmake -f makefile.vc in the mapscript/csharp directory
>To test your compilation:
>1. Create a new VS project
>2. Add reference to mapscript_csharp.dll
>3. Add reference to Microsoft Visual
>Studio8\VC\redist\x86\Microsoft.VC80.CRT\Microsoft.VC80.CRT.manifest
>4. Use mapscript objects within your code
>5. Compile your solution
>6. Copy the compiled mapscript.dll, libmap.dll and the dependent dll-s into
>your app directory.
>7. Run
>If your are not using the IDE (eg. to try the samples like drawmap.exe) you
>should create a proper manifest file along with your .exe declaring a
>reference to the CRT assemblies, otherwise the program will not run.
>I hope not to forget anything.
>If it is required precompiled binaries could be created for download, but
>one should define the possible reasonable variations of the required library
>usage.
>Best Regards,
>Tamas Szekeres
>On Tue, 28 Feb 2006 08:44:39 -0600, John Cole <john.cole at UAI.COM> wrote:
>>Hello,
>> Is someone maintaining a binary of C# mapscript (.net 2.0)?
>>Thanks,
>>John Cole
