basic configuration
Pericles S. Nacionales naci0002 at UMN.EDU
Fri Mar 10 03:01:58 EST 2006
Change the value of IMAGEURL from '/tmp/' to '/ms_tmp/'.  It looks like
there could be something wrong with your template as well.  See this
line: <input type="image" name="img" src="http://tmp/EX2.5_11415303.png"
width="400" height="300" border="0" />
Check the template file and make sure it looks like this:
<input type="image" name="img" src="[img]" width="400" height="300"
border="0" />
Good luck!
-Perry
Albert Garcia wrote:
> Hello,
> I have a mapserver 3.6.7 application. I try to migrate to the last version
> of mapserver and I have installed the ms4w pack with the default directory
> structure. (using windows and apache).
> To learn about this new version I have installed the mapserver tutorial too
> (http://mapserver.gis.umn.edu/docs/tutorial/tutorial) . The section1, static
> maps runs ok. I have a problem in section 2 with the html templates:
> mapserver create the maps in the tmp directory: C:\ms4w\tmp\ms_tmp> but it
> not appears in the application html.
> This is the command line I use:
> http://gis002/cgi-bin/mapserv.exe?root=%2Ftutorial&program=%2Fcgi-bin%2Fmaps
> erv.exe&map_web_template=example2-2.html&map=%2Fms4w%2Fapps%2Ftutorial%2Fhtd
> ocs%2Fexample2.map&imgext=510141+4676372+519900+4683247&imgxy=400.0+300.0&la
> yer=orto&mode=browse&submit=Refresh&zoom=0 (intranet only)
> This is the section of map file:
> WEB
>     TEMPLATE  'example2-2.html'
>     IMAGEPATH '/tmp/ms_tmp/'
>     IMAGEURL  '/tmp/'
>   END # Every object in MapServer must have an END.
> and this is the section of the html:
> <form name="mapserv" method="GET" action="/cgi-bin/mapserv.exe">
> <!-- HIDDEN MAPSERVER CGI VARIABLES -->
>     <input type="hidden" name="root" value="/tutorial">
>     <input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
>     <input type="hidden" name="map_web_template" value="example2-2.html">
>     <input type="hidden" name="map"
> value="/ms4w/apps/tutorial/htdocs/example2.map">
>     <input type="hidden" name="imgext" value="510141 4676372 519900
> 4683247">
>     <input type="hidden" name="imgxy" value="400.0 300.0">
> <!-- DISPLAY THE MAPSERVER-CREATED MAP IMAGE -->
> 	    <td colspan="3" align="center" valign="top">
> 	    </td>
> Thanks for all!!!
