Point Layer Won't Draw
Brock Anderson
banders at REFRACTIONS.NET
Mon Mar 13 16:08:24 EST 2006
Lawrence,
It's hard to diagnose your problem without seeing the map file. Can you
post your map file (or at least the problem layer) to the list?
Often when layers don't draw as expected it's because the layer's
PROJECTION block is set up wrong. Check that you've got it set to the
projection that your data is stored in.
Brock
Lawrence Hartpence wrote:
>Hello,
>I am using Mapserver 4.6 on a windows machine with IIS. I have the ms4w
>build installed on my machine.
>I have a layer named ctl2005. It is a shapefile. It won't draw. I have
>tried different mapfiles. I tried using different symbology. Nothing
>works. It does draw in ArcIMS.
>Does anyone have any ideas what is going on here?
>Thanks!!
>Lawrence Hartpence
>GIS Coordinator
>101 1st St N
>Newton IA 50208
>641-792-3084
>hartpence_gis at co.jasper.ia.us
