Mapserver in an IIS cluster
Chip Taylor work at XWB.COM
Mon Mar 13 17:37:41 EST 2006
I am running Mapserver 4.6 CGI on Windows/IIS and attempting to make it work
in a twoserver cluster.  I have all the shape files, map files, template
files etc duplicated on both servers.
When I attempt to generate a map it appears that the template is generated
on one server but the image may be generated in the /tmp directory of the
other server, causing no image to appear on the HTML page.  If I look into
the /tmp directory of both servers I will find the missing image on one of
them and can double click and display it just fine.  If I refresh the HTML
page enough times they will sync and the image will appear.
Obviously this is a problem.  Can anyone running a cluster help me with
this?
Chip Taylor
