PERL Mapscript
Stephen Davies
sdc at SDC.COM.AU
Wed Mar 15 02:49:21 EST 2006
Sorry; a mistake in my posting.
The actual invocation of the script was:
./genpics q 1 jpg 139.5143351 -34.7459112 139.5278707 -34.7207
The problem remains.
Cheers and thanks
Stephen
On Wednesday 15 March 2006 17:01, Manfred Meier wrote:
> > ./genpics q 1 139.5143351 -34.7459112 139.5278707 -34.7207
> Is there a parameter missing before "139.5143351"? minx is ARGV[3] in
> your program.
> Hope that helps
> Manfred
> Stephen Davies schrieb:
> > I am having my first attempt at using PERL/Mapscript to save map
> > images to files and am not getting too far.
> > I have a map file that works perfectly when used with:
> > http://server/cgi-bin/mapserv?map=/tmp/q.map&mapext=139.5143351+-34
> >.7459112+139.5278707+-34.7207
> > I have the following PERL test bed:
> > #! /usr/bin/perl
> > # args are UID (for mapfile), pic sequence #, image type
> > (extension), map extent
> > use strict;
> > use mapscript;
> > my $uno = $ARGV[0];
> > my $seq = $ARGV[1];
> > my $ext = $ARGV[2];
> > my $minx = $ARGV[3];
> > my $miny = $ARGV[4];
> > my $maxx = $ARGV[5];
> > my $maxy = $ARGV[6];
> > my $mapfile = "/tmp/$uno.map";
> > my $map = mapscript::mapObj->new($mapfile);
> > $map->setExtent($minx,$miny,$maxx,$maxy);
> > my $img = $map->prepareImage();
> > $img = $map->draw();
> > my $fname = "/var/www/html/status_images/$uno_$seq.$ext";
> > print "$fname\n";
> > $img->save($fname);
> > Called as:
> > This generates a blank jpeg file (of some 2800 bytes).
> > What am I missing?
> > Cheers and thanks,
> > Stephen Davies
> > MapServer version 4.8.0-rc2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> > SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
> > SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> > INPUT=SHAPEFILE
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
