Mapserver caching and map generation
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Wed Mar 15 14:13:17 EST 2006
Ramesh,
This has been discussed quite extensively of late. Mapserver does not do
caching at all. Every mapserver request will generate a new image. If
you want to do caching, you might look at ka-map which creates a tile
cache and serves the tiles if they exist or generates them if they do
not. It is an AJAX client that uses mapserver on the back-end and looks
like google.
-Steve W.
Ramesh Karra wrote:
> Hi,
> I have a related question -
> I have a map that has 4 tiles at the top level and more tiles as I zoom
> in. Let's say total tiles at all levels is 256. Once all these 256 tiles
> are generated, mapserver will just serve these from the cache and will not
> generated the same tiles again and again, Am I right?
> If I configure some kind of RAM based file system as the mapserver cache
> directory, then all requests will be served from the memory and the
> performance would be great. I would appreciate if some one could confirm
> that this is the way mapserver works.
> Thanks
> Ramesh
