WMS projection error...
Frank Warmerdam warmerdam at POBOX.COM
Wed Mar 15 16:36:45 EST 2006
John Cole wrote:
> I'm trying to use Gaia 2.0.4 from www.thecarbonproject.com to view a map map
> 4.8.1 mapserver from MS4W (using IIS and not Apache) and I'm getting the
> following error:
> msProcessProjection(): Projection library error. No such file or directory
> If I browse to the map using mode=browse it works fine (it did have a
> similar error through the browser, but a config fixed it and adding the
> PROJ_LIB path to my environment variables also fixed it).
> Hitting the same mapfile with mapserver 4.4 works fine.
> Is there another parameter to tell wms where the proj files are?
John,
One way of handling this is to have a CONFIG directive on your map object.
I think this would look something like:
MAP
   CONFIG "PROJ_LIB" "C:/PROJ/NAD"
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
