WAN vs LAN access problems
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Thu Mar 16 13:53:29 EST 2006
Does your machine have an internal and external IP address?
If you view the HTML source of your application, what URL do the images
reference?
Best regards,
Bart
Sears, Jeremy wrote:
>Hi All,
>IM having a problem with my mapserver installation ....
>I have mapserver/chameleon setup with ms4w on winserver2003.
>When I view my application from our LAN (either localhost or another
>computer on the LAN) the application works fine.
>However, when I attempt to view the application from the WAN, chameleon's
>elements work but neither the main map image nor the keymap image work.
>I have the entire ms4w package installed in in a location off the root like:
>/adirectory/anotherdirectory/ms4w
>Does anyone have any thoughts as to why the app works fine when accessed
>from LAN but breaks when accesing through WAN?
>Thanks
>Jeremy
OSGIS, Open Source GIS
http://www.osgis.nl
