WAN vs LAN access problems
Sears, Jeremy Jeremy.Sears at CCRS.NRCAN.GC.CA
Thu Mar 16 15:08:57 EST 2006
whoa, Im not sure what just happened there, It seems my original post and
Bart's response got bounced twice ...
To add to my response to Barts reply,..
I believe that the proxy server that directs requests to the internal server
is IIS.
So the situation goes somthing like:
http request for a map ----> IIS proxy ------> Apache/Mapserver
then back out to the web like:
Apache/mapserver ---------->IIS proxy -------> web browser
Could there be potential issues with such a senario?
Thanks
Jeremy
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Bart van den Eijnden (OSGIS)
Sent: March 16, 2006 1:53 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WAN vs LAN access problems
Does your machine have an internal and external IP address?
If you view the HTML source of your application, what URL do the images
reference?
Best regards,
Bart
Sears, Jeremy wrote:
>Hi All,
>IM having a problem with my mapserver installation ....
>I have mapserver/chameleon setup with ms4w on winserver2003.
>When I view my application from our LAN (either localhost or another
>computer on the LAN) the application works fine.
>However, when I attempt to view the application from the WAN, chameleon's
>elements work but neither the main map image nor the keymap image work.
>I have the entire ms4w package installed in in a location off the root
like:
>/adirectory/anotherdirectory/ms4w
>Does anyone have any thoughts as to why the app works fine when accessed
>from LAN but breaks when accesing through WAN?
>Thanks
>Jeremy
OSGIS, Open Source GIS
http://www.osgis.nl
