Setting up a value for a classitem expression in address bar -
possible?
Dmitri Mizerkin
mizerkin at WIRZ-KOELN.DE
Fri Mar 17 05:35:41 EST 2006
Hello all!
I'm wondering if it is possible to set up a value for a classitem expression
in the address bar, not directly in the map-file. That means that I want to
have something like this in the map-file:
LAYER
NAME Sel_Street
DATA Streets
STATUS OFF
TYPE LINE
CLASSITEM "OBJECTID"
CLASS
NAME 'Selected street'
#EXPRESSION '28' #This is the value, which should be set dynamically
STYLE
COLOR 255 0 0
END
END
END
and activate the layer setting up a value for the expression-part in the
reference to the active page (for example, like this:
http://localhost/mapserv.exe?map=/ms4w/apps/my/streets.map&mode=browse&layer=Sel_Street&expr=28).
Can someone help me out?
Thanks,
Dmitri
View this message in context: http://www.nabble.com/Setting-up-a-value-for-a-classitem-expression-in-address-bar---possible--t1297050.html#a3453450
Sent from the Mapserver - User forum at Nabble.com.
