filled symbols bleed at edge of map
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Mar 21 16:26:47 EST 2006
Wow, that sucks (the bleeding I mean). It looks like a clipping issue in
GD with filled ellipses. Should be easy enough to track down...
Steve
>>> Ken Lord <kenlord at GMAIL.COM> 3/21/2006 2:53:46 PM >>>
Hi List,
I've seen the same problem affecting legend icons when the symbol is
bigger than the size of the icon, again along the bottom.
http://cariboo-gold.no-ip.info/
-- Turn on the BC Minfile layer, found in the 'Exploration Layers'
folder of the 'Layer Controls' tab.
--Then click the 'Legend' tab to see the problem.
It can also be seen in the larger symbols of the 'Soil Geochem by
Percentiles' layer found in the 'Soil / Geochem Samples' folder of the
This issue has existed for so long that I had assumed it was well known.
Cheers,
Ken Lord
Vancouver BC
On 3/21/06, Christopher Condit <condit at sdsc.edu> wrote:
> Hi Steve-
> I'm very interested in this bug, as I am having the same problem with an
> Oracle Spatial layer through my WMS server. To answer your question: in
> my application, I've only seen this occur on bottom edge of a tile. If
> a point intersects the top, right, or left edge, it is truncated
> properly, even when filled.
> Thanks,
> Chris
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Steve Lime
> Sent: Tuesday, March 21, 2006 12:10 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] filled symbols bleed at edge of map
> Thanks Tim, will have a look. This looks like a GD problem to me, but
> I'll try to confirm that with a GD-only test case. Does it do this along
> all edges or just the bottom?
> Steve
> >>> Tim Schaub <tim at COMMENSPACE.ORG> 3/21/2006 11:37:12 AM >>>
> I've noticed that filled symbols bleed along the edge when they are
> intersected by the map extent.
> This can be seen with a filled ellipse here
> http://mapserver.commenspace.org/test/ellipse_filled.png
> With FILLED set to FALSE, the result looks better
> http://mapserver.commenspace.org/test/ellipse_unfilled.png
> I couldn't find a bug related to this, so I filed one here
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1719
> Hope that's enough detail,
> Tim
