Palletizing Bulk Tiled Imagery
Rahkonen Jukka Jukka.Rahkonen at MMMTIKE.FI
Thu Mar 23 04:15:43 EST 2006
> I've worked with gdalwarp on a per-tile basis but that makes the output
> tiles parallogrammed as per the re-projection and this causes me trouble
>>when
> I go to seamlessly composite the new tiles back together.
When it comes to get new seamless tiles, for my mind I have received just perfect results with gdalwarp by using the following command:
gdalwarp  -s_srs EPSG:2392 -t_srs EPSG:25835 -tr 0.5 0.5 -te 402000 7182000 408000 7188000 Jpeg2000.vrt EUREF_mapsheet.tif
Essential here is to use a virtual mosaic as a source file.  A modified gdal_merge script was once posted to gdal_dev mailing list, that creates GDAL/VRT file from a file list in seconds.  In practise I feed the extents of the resulting images and corresponding file names as variables from another bat-file calling this one.  There is no need to separately put new tiles together, everything will be ready with one run.
Regards,
-Jukka Rahkonen-
