Setup Mapserver IIS
Pericles S. Nacionales naci0002 at UMN.EDU
Thu Mar 23 11:09:10 EST 2006
Hugo Girard wrote:
> Hi all, i follow this tutorial:
>   http://mapserver.gis.umn.edu/docs/howto/setupiis
> <http://mapserver.gis.umn.edu/docs/howto/setupiis>
> to setup mapserver on iis. Everythings was ok. But i use this command to
> generate my map :
> http://localhost/MSProjects/cgi-bin/mapserv.exe?map=C:\Documents and
> Settings\Administrateur\Bureau\randonneurs\map\main.map&mode=map
> and an error appear *BAD REQUEST (INVALID HOST NAME)*. I think my
> command is not good. Someone can help me plz !!!!!
Is the IIS service running?  What happens if you just type
If the above looks right, then you should check your permissions.
Chances are a normal user don't have permission to access an
administrator's directory. ;)  Move your application to a different
directory.
-Perry
