How to increase resolution of image?
Paul Moen
pmoen at STATE.ND.US
Thu Mar 23 10:50:33 EST 2006
Thank you for your response Flavio.
Does that mean that all sizes of map elements must be sized larger so they
scale with the map?
Does anyone know if this is something that is being worked on or has been a
feature request? Can GD or Imagemagick scale the image to an 8 x 8 at 150
dpi without degrading the image?
On 3/23/06 2:30 AM, "Flavio Hendry" <flavio at TYDAC.CH> wrote:
> Hi Paul
> "resolution" is normally defined as dots or pixels per inch. a "naked"
> image has therefore no resolution, just a size. anyway, you are on the
> right way, you just have to "force" your 1200x1200 pixels image into an
> 8"x8" rectangle in your pdf. which would in this case end up to 1200
> dots / 8 inch = 150 dpi.
> Mit freundlichem Gruss / Best Regards
> Flavio Hendry
> TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
> ############ Mit freundlichen Gruessen / Kind Regards
> ############ mailto:flavio at tydac.ch
> ############ TYDAC AG - http://www.tydac.ch
> #### #### Geographic Information Solutions
> #### #### Luternauweg 12 -- CH-3006 Bern
> ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
Thank you,
Paul T. Moen
pmoen at state.nd.us
701-328-2434
701-328-3696 (fax)
ND State Water Commission
