Setup Mapserver IIS
Stephane Lessard
LESSARDST at DFO-MPO.GC.CA
Thu Mar 23 10:44:31 EST 2006
Hugo Girard... World Strongest Man?
It might simply be a problem with your IIS installation? Try
http://localhost <http://localhost> , or http://127.0.0.1 <http://127.0.0.1>
If you are on Win2003, this might help you:
http://www.mrtweak.com/windows-servers/fixing-a-bad-request-invalid-hostname
-400-error-on-windows-iis/
<http://www.mrtweak.com/windows-servers/fixing-a-bad-request-invalid-hostnam
e-400-error-on-windows-iis/>
Hope this helps!
Stéphane Lessard
_____
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Hugo Girard
Envoyé : 23 mars 2006 09:09
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Setup Mapserver IIS
Hi all, i follow this tutorial:
<http://mapserver.gis.umn.edu/docs/howto/setupiis>
to setup mapserver on iis. Everythings was ok. But i use this command to
generate my map :
http://localhost/MSProjects/cgi-bin/mapserv.exe?map=C:\Documents and
Settings\Administrateur\Bureau\randonneurs\map\main.map&mode=map
and an error appear BAD REQUEST (INVALID HOST NAME). I think my command is
not good. Someone can help me plz !!!!!
Thanks
Hugo Girard
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060323/4598a1b9/attachment.html
