Annotation for line layer problem
Paul Moen
pmoen at STATE.ND.US
Thu Mar 23 13:41:19 EST 2006
An update.
The annotation layer for the line shape works when the symbol is not used.
Therefore, something is wrong with the way I use my symbol. This worked in
4.8.1. So, the new question is what is wrong with my symbol and the way I
am using it?
On 3/23/06 9:35 AM, "Paul Moen" <pmoen at state.nd.us> wrote:
> My ANNOTATION layer line types worked in 4.8.1 and do not in 4.8.2. The httpd
> daemon takes all
> the processor and times out in 60 seconds when I zoom to a level the label
> appears. This only
> seems to be a problem on the annotation for line layers.
> LAYER # Line Shape File
> NAME "a_State and Federal Roads"
> DATA roadsstatefed
> GROUP "Transportation"
> TEMPLATE "noexist"
> STATUS ON
> TYPE ANNOTATION
> LABELITEM "HWY"
> CLASS
> TYPE ANNOTATION
> MAXSCALE 1000000
> NAME "0_0"
> EXPRESSION ('[RTE_SIN]' eq 'S')
> COLOR 0 0 0
> SYMBOL "../symbols/largerimages/sthwy.gif"
> LABEL
> MINFEATURESIZE 50
> MINDISTANCE 150
> SIZE SMALL
> COLOR 0 0 0
> END
> END # Standard Road Signs - State
> END
> This works for the polygon layer countypoly.
> LAYER # Polygon shap file
> NAME "a_Counties"
> DATA countypoly
> GROUP "Political Boundaries"
> STATUS ON
> TYPE ANNOTATION
> LABELITEM "NAME_CAPS"
> CLASS
> NAME "0"
> TYPE ANNOTATION
> EXPRESSION ('[NAME_CAPS]' eq 'MOUNTRAIL')
> MINSCALE 500000
> LABEL
> FONT timesbold
> TYPE TRUETYPE
> OUTLINECOLOR 150 255 150
> SIZE 7
> COLOR 100 100 100
> ANGLE AUTO
> PARTIALS FALSE
> POSITION CC
> END
> END
> I get no errors in http error_log or in the console.log. Did something change
> that makes my
> annotation layer definitions for lines wrong? Can anyone see if there is
> something that I am
> missing or did something break in 4.8.2?
> Thanks,
> Paul Moen
Paul T. Moen
701-328-2434
701-328-3696 (fax)
ND State Water Commission
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060323/263ddcad/interstate.obj
