drawLabelCache problem in 4.8.2
Jeff Hoffmann
jeff at PROPERTYKEY.COM
Thu Mar 23 14:09:27 EST 2006
I'm setting up a new server and decided to go with the newest version of
MapServer, but I'm having a problem with getting one of my perl scripts
to run. I've isolated the problem to the call to drawLabelCache -- once
the script hits that line, it pegs the CPU until the web server request
times out. I've run the same script on probably every 4.x version of
MapServer there is up til now without problems, so I went and grabbed a
copy of the 4.8.1 source and compiled it on that machine & it worked
fine, so I'm guessing that some sort of bug got introduced between releases.
Jeff Hoffmann
jeff at propertykey.com
