How to increase resolution of image?
Flavio Hendry flavio at TYDAC.CH
Fri Mar 24 05:04:52 EST 2006
Hi Aaron
> Yes, the map elements should be scaled as well. Otherwise, when
> printed, they appear smaller than the web-map.
If you use sizeunits in "real world units" such as "SIZEUNITS inches"
you get in the PDF the same image as on-screen. They only appear smaller
if you use pixels which is the default.
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############      Mit freundlichen Gruessen / Kind Regards
############             mailto:flavio at tydac.ch
############         TYDAC AG - http://www.tydac.ch
####    ####        Geographic Information Solutions
####    ####         Luternauweg 12 -- CH-3006 Bern
############   Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
