Filter vs. seperate shapefiles
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Mar 27 17:59:02 EST 2006
Kevin,
It is faster to filter that data into separate files. There is little
cost to have a few extra layers, but to filter the layer requires
looking at every record for every request.
For performance always preprocess as much as you can.
-Steve
Kevin Flanders wrote:
> Is it better (ie. faster) to have several map layers reference the same
> shapefile using FILTER statements to specify the shapes they reference,
> or to create several different shapefiles.....one for each class (on/off
> control is required for each layer, which is why we are not simply using
> different CLASSES).
> Kevin
