WMS time and Oracle Spatial
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Mar 28 08:30:25 EST 2006
Bart,
I personnaly did not test it on an oracle layer but here is how It is
supposed to wirk : the wms time support would set the filter element of
the layer with the time field and the time string as it was a normal
attribute. Something like this ([time_field] = time_value) (timefield is
extrcated from metedata on the layer and timevalue comes from the wms
request). This sould normally translate into a a valid sql query
(something like where + the filter string). If you are able to test it
let me know.
Later,
Eijnden, B. van den (Bart) wrote:
> Hi list,
> has the WMS time support of Mapserver been fully tested against Oracle
> Spatial? I do see a note in the WMS Time HOWTO about PostGIS but not about
> Oracle Spatial, so I would like some confirmation that WMS time against the
> native Oracle Spatial driver would work .....
> Thanks in advance.
> Best regards,
> Bart
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
