[UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS] Using a web image as a ma p layer
Mark Howard mhoward at AKIMEKA.COM
Wed Mar 29 13:42:33 EST 2006
Thanks Antti,
Yes if I save the file locally and refresh it often, I can do that. I
was hoping to access it directly using the URL - and just supply an
extent for the map file; or something like that.
Mark
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Antti Roppola
Sent: Tuesday, March 28, 2006 2:54 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] [UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS]
I did this once by creating a world file to georeference the image,
It was quite a while ago but I recall it was pretty straight forward.
For your example, your GDAL build will need to support GIF or you
will need to convert the image to a supported format first.
Antti
Behalf Of Mark Howard
Sent: Wednesday, 29 March 2006 11:10 AM
Subject: [UMN_MAPSERVER-USERS] Using a web image as a map layer
Anybody know how to use an image off the web as a map layer?
I'm thinking of an image that's updated periodically - such as:
http://www.intellicast.com/WeatherImg/Satellite/world.gif
Ideas? (simple ideas?)
TIA!!
Mark
IMPORTANT - This message has been issued by The Department of
Agriculture, Fisheries and Forestry (DAFF).  The information transmitted
is for the use of the intended recipient only and may contain
confidential and/or legally privileged material.  It is your
responsibility to check any attachments for viruses and defects before
opening or sending them on.
Any reproduction, publication, communication, re-transmission,
disclosure, dissemination or other use of the information contained in
this e-mail by persons or entities other than the intended recipient is
prohibited.  The taking of any action in reliance upon this information
by persons or entities other than the intended recipient is prohibited.
If you have received this e-mail in error please notify the sender and
delete all copies of this transmission together with any attachments.
If you have received this e-mail as part of a valid mailing list and no
longer want to receive a message such as this one advise the sender by
return e-mail accordingly.  Only e-mail correspondence which includes
this footer, has been authorised by DAFF
