Java Mapscript - querybyattribut
Oliver Wesp
wesp at GDV.COM
Thu Mar 30 00:46:00 EST 2006
Dear List,
I' struggling with queryByAttributes on an attribute field with german
umlauts using java mapscript.
The odd thing is that the same thing works fine with php mapscript and
when I use expressions in my mapfile. I'm using a shapefile as datasource.
Here is what I do:
layer.queryByAttributes(map,"KREIS_NAME", "/Südliche Weinstraße/",
mapscriptConstants.MS_MULTIPLE);
layer.open();
System.out.println( "Result Count: " +layer.getNumResults() );
layer.close();
The result is always null while replacing the qstring with something
that doesn't contain special characters (e.g.
'Mainz-Bingen') works fine.
As noted above the following layer definition in a mapfile works fine
LAYER
NAME kreis
STATUS DEFAULT
TYPE polygon
DATA "/tmp/subset"
TEMPLATE "kreis.html"
CLASSITEM KREIS_NAME
CLASS
NAME Boundary
COLOR 128 128 0
OUTLINECOLOR 0 0 0
EXPRESSION /Südliche Weinstraße/
END
END
but this does not:
layer.setClassitem("KREIS_NAME");
classObj cl = new classObj(layer);
cl.setName("Classname");
cl.setExpression("/Südliche Weinstraße/");
I use Mapserver 4.8.1 on W2k, Tomcat 5.0.28.
I can provide some sample data, just in case someone likes to reproduce.
Any help is appreciated.
best regards
Oliver
Dipl.-Geogr. Oliver Wesp
Gesellschaft fuer geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
