html legend classes; data encoding; (noted python mapsript +
J. Parapar
listario at GMAIL.COM
Wed Oct 4 05:17:01 EDT 2006
Hello Karpi
Quoting the documentation about HTML Legends (
http://mapserver.gis.umn.edu/docs/howto/html_legend/#class-block):
"opt_flag=14 means do not show classes in the legend that are out of scale."
Hope this helps
Best regards,
Jorge
2006/10/3, karpi <karpi.lists at email.cz>:
> django templating)
> Reply-To:
> hello, Im spent some time with my first mapserver cgi web application.
> here is its early version:
> http://gismaster.liberix.cz/cgi-bin/mapserv?map=%2Fvar%2Fwww%2Flocalhost%2Fhtdocs%2Fnewmap%2Fczrep.map&imgext=330491.333543+5529453.205715+456794.204419+5632791.918249&zoomsize=2&layer=vodn%C3%AD_plochy&layer=vodn%C3%AD_toky&layer=m%C4%9Bsta_plochy&layer=obce_class&cellsize=229.641583&vyhledat=&mode=browse&mapsize=550+450&img.x=80&img.y=362
> My biggist question at this point are:
> 1) can i hide legend items, of that classes, which are not rendered
> (maxscale of class) as is done in common bitmap legend ??
> my legend template is short:
> [leg_layer_html order_metadata=legend_order opt_flag=15]
> <input type=checkbox name=layer value=[leg_layer_name] [if name=layer_status oper=eq value=1] CHECKED [/if] [if name=layer_status oper=eq value=2] CHECKED DISABLED [/if] > [leg_layer_name] <br>
> [/leg_layer_html]
> [leg_class_html opt_flag=0]
> <img src="[leg_icon width=30 height=20]" width=30 height=20> [leg_class_name] <br>
> [/leg_class_html]
> 2) my data are saved in different encoding (iso-8859-2) then mapfile,
> templates and all web is (utf8) This discrepancy caues errors as this:
> http://localhost/cgi-bin/mapserv?map=%2Fvar%2Fwww%2Flocalhost%2Fhtdocs%2Fnewmap%2Fczrep.map&imgext=441771.353638+5581229.641642+457559.212498+5594146.980709&zoomsize=2&layer=vodn%C3%AD_plochy&layer=vodn%C3%AD_toky&layer=m%C4%9Bsta_plochy&layer=obce_class&cellsize=28.705198&vyhledat=&mode=query&mapsize=550+450&img.x=282&img.y=231
> (Jměno obce: Dobříš)
> Can i force mapserver to respect different encoding in the data files?
> Thanks for any kind of your replys
> ( Ive also try python mapscript + django templating solution, but when
> i approached creating legends through layer.getClass(j).drawLegendIcon
> rendering and serving of maps begun extremly cpu consuming and slow :(
> karpi from
