Mapscript adding class with PHP
Eijnden, Bart van den (AGI) b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Oct 4 05:25:23 EDT 2006
Arie,
can you save your MAP using
$map->save('<filename>');
And post the output LAYER definition?
Also, have you set CLASSITEM on your LAYER?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: Arie Mijnlieff [mailto:mijnlief at xs4all.nl]
Verzonden: woensdag 4 oktober 2006 11:03
Aan: Eijnden, Bart van den (AGI)
CC: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] Mapscript adding class with PHP
Bart !
My code is now:
$this_layer = $map->getLayerByName('countries');
$new_class = ms_newClassObj($this_layer);
$new_class->setExpression('Russia');
$new_class->set('name','Russia');
$new_class->label->outlinecolor->setRGB(255,255,255);
$new_class->label->set(minfeaturesize,40);
$new_style = ms_newStyleObj($new_class);
$new_style->color->setRGB(100,100,100);
$new_style->outlinecolor->setRGB(255,255,255);
$img=$map->draw();
$img->saveImage("/var/www/html/mapdemo/images/test.jpg");
Doesnt work however..
I really appreciate your help !
Arie
On 4-okt-2006, at 10:06, Eijnden, Bart van den (AGI) wrote:
> Arie,
> you can best use a style object. Example:
>     $oClass = ms_newClassObj($oLayer);
>     $oStyle = ms_newStyleObj($oClass);
>     $aColor[0] = 0;
>     $aColor[1] = 0;
>     $aColor[2] = 0;
>     if ($HTTP_FORM_VARS["COLOR"]!= "")
>       $aColor = explode(",", $HTTP_FORM_VARS["COLOR"]);
>     $oStyle->color->setRGB($aColor[0], $aColor[1], $aColor[2]);
> Best regards,
> Bart
> Van: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Arie Mijnlieff
> Verzonden: woensdag 4 oktober 2006 10:06
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> Hi Murat !
> No this doesnt solve the problem:
> PHP Fatal error:  Call to a member function on a non-object in /var/
> www/html/mapdemo/bulgaria/test.php on line 13
> color is not an attribute of the class object.. Maybe i should try to
> define a new layer with php for each country that i would like to
> paint..
> Thanks for your suggestion !
> Arie
> On 4-okt-2006, at 8:38, Murat BEYHAN wrote:
>> Hi Arie,
>> please try the following in yor php script,
>> I'm new on PhpMapscript so. I hope this solve your problem
>>> $new_class->setExpression('Australia');
>>> $new_class->set('name','Australia');
>>   $new_class->color->setRGB(255,0,0);////////////////here you
>> should add
>> regards
>> Murat
>> On Tue, 3 Oct 2006 21:35:33 +0200, Arie Mijnlieff wrote
>>> Hi,
>>> I want to show countries in my world map based on a form with
>>> checkboxes.
>>> If I check Argentina and Australia i would like to show both
>>> countries in red, whereas the other are in another color. If i
>>> change  the selection in Australia and India i would like Australia
>>> and India  to be red.
>>> I have a .map file with a layer called countries. In that layer i
>>> have a class:
>>>     CLASS                   # Start of CLASS object
>>>        NAME 'Argentina'
>>>        EXPRESSION 'Argentina'
>>>        OUTLINECOLOR 100 100 100
>>> 	  COLOR 255 255 150
>>>        LABEL
>>> 	   SIZE LARGE
>>> 	   OUTLINECOLOR 255 255 255
>>> 	   MINFEATURESIZE 40
>>>        END
>>>      END                     # End of CLASS object
>>> So i thought if Australia is checked, i add a class object to my
>>> layer using php with the same colors:
>>> Australia will not be red however. I do not understand how i can
>>> change the color of my new class. I succeeded only to change the
>>> color of the label.. What do i do wrong ?
>>> If i change the color of an existing class i can see that change
>>> however..
>>> $my_class = $this_layer->getClass(0);
>>> $my_class->setExpression('Australia');
>>> $my_class->set('name','Australia');
>>> Any help will be appreciated !!
>>> Arie
>>> This message has been scanned for viruses and
>>> dangerous content by MailScanner, and is
>>> believed to be clean.
>> Open WebMail Project (http://openwebmail.org)
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
Disclaimer
