MySql Spatial Database
Frank Warmerdam
warmerdam at POBOX.COM
Wed Oct 4 10:49:10 EDT 2006
Murat BEYHAN wrote:
> Dear Bart,
> thank you for your advice.
> I have tried the followings
> ogr2ogr -f MySQL MySQL:testogr,user=root,password=passmysql cities.shb -nln
> iller -update -overwrite -lco GEOMETRY_NAME=SHAPE2
> This is creates 3 tables in mysql tables in testogr database.
> the names of the tables are
> geometry_columns,
> cities,
> spatial_ref_sys
> then I have doubt I have cities shape files the tail of the files are
> shp shx sbn sbx these are esri files. I don't know Which one should be use
> for this?
Murat,
In the above commandline you show cities.shb as the input. This should
be cities.shp, perhaps this was just a typo if things worked? Generally
speaking OGR depends on the .shp, .shx and .dbf file. The .sbn and .sbx
spatial indexes are ignored.
> And How can I connect and read data by using ogr connection from map file.
You would use:
CONNECTIONTYPE OGR
CONNECTION "MySQL:testogr,user=root,password=passmysql"
DATA "cities"
for your layer.
> I have an experiment if the data stored regularly as lat and lon in the table
> I can read those for draw point. But My problem if I have polygone or line
> data in mySql How can I read those data to create a layer on my map file by
> using OGR. So I'm trying to use spatial database.
Note that a true spatial table in MySQL is handled very differently from
a table with lat and lon columns which is usually handled via ODBC and
OVF.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
